38mpg
  • Iansea
16 Jul 2012 21:27 - 16 Jul 2012 21:30 #44298 by Iansea
Replied by Iansea on topic Re: 38mpg
I've had a thought about the reduced mpg experienced by those folks using AT2's. Surely, as the vehicles odometer is calibrated using the standard size tyres, then changing to tyres with a larger rolling radius will cause the odometer to under read as you'll be covering a greater distance with every revolution of the tyre.
This could account for some of of the difference although the more aggressive tread pattern probably has an effect as well.
Last edit: 16 Jul 2012 21:30 by Iansea. Reason: spelling
  • adamatdraycott
17 Jul 2012 07:08 #44311 by adamatdraycott
Replied by adamatdraycott on topic Re: 38mpg
Iansea wrote: I've had a thought about the reduced mpg experienced by those folks using AT2's. Surely, as the vehicles odometer is calibrated using the standard size tyres, then changing to tyres with a larger rolling radius will cause the odometer to under read as you'll be covering a greater distance with every revolution of the tyre.
Yes the rolling circ will make a difference... but... i too am running AT2's and average 32-33mpg town driving and 35-38 on long distance
21 Jul 2012 08:51 #44656 by gilburton
Replied by gilburton on topic Re: 38mpg
Just done my first calculation since getting the car. Around town/urban 34mpg.
The vvt is a much better car overall compared with my old 1998 sohc. It's much quieter and smoother and doesn't roll so much on roundabouts but I guess more expensive to sort out. :)
I started off high and worked my way down ever since :-)
  • Municipal Waste
02 Nov 2012 14:03 #51977 by Municipal Waste
Replied by Municipal Waste on topic Re: 38mpg
Through the summer I get about 28mpg and through the winter that drops to about 20mpg. :angry:
02 Nov 2012 16:48 #52002 by maverick
Replied by maverick on topic Re: 38mpg
I have 16" GV Rims, a 6-1 T-case, a heavy winch on the front -- so MPG is always a problem - I reckon it does around 20mpg, but actually I don't care ...
I fill it up, when it needs more, I fill it up again!
Jalapeño, IISY?
02 Nov 2012 18:26 - 02 Nov 2012 18:28 #52010 by dirtydogz
Replied by dirtydogz on topic Re: 38mpg
I agree with Maverick,if you don't like how much you get to the gallon sell your JIMNY and buy a moped. :dry:
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 02 Nov 2012 18:28 by dirtydogz.
Time to create page: 0.775 seconds
