Front brakes
- emu88
11 Dec 2015 10:43 #158301
by emu88
Replied by emu88 on topic Front brakes
I've found just the pins at bigg red, no bolts of course but using them with the old bolts will also be fine I suppose?
11 Dec 2015 11:13 #158302
Replied by mlines on topic Front brakes
everyone sells the kit with the rubber parts, this is because the rubber parts are often the real cause of the issue.
See
www.bigjimny.com/index.php/bigjimny-blog...sive-mistake-v15-248
I would always get new rubber boots
See
- mickt
11 Dec 2015 19:42 #158315
by mickt
Replied by mickt on topic Front brakes
Concur with Martin.
12 Dec 2015 23:10 #158389
by kirkynut
Replied by kirkynut on topic Front brakes
Just been poking around in the BigJimny shop and seen Martin sells them:
www.bigjimny.com/store/caliper-fitting-k...in-suzuki-jimny.html
- emu88
13 Dec 2015 22:27 #158465
by emu88
Thanks all. I already have the new rubber parts though. So I just bought 4 new sliders to go with them.
- emu88
15 Dec 2015 18:48 - 15 Dec 2015 18:51 #158581
by emu88
Hmm I got the new sliders. The end flares are slightly wider as you can see in the photo, and the diameter of the body is 12.9mm whereas the old ones are 13.5mm. I can rattle the new ones around in the caliper more than the old ones. Also the groove where the rubber sits is 2.5mm wide on the new ones but 3.0mm on the old... Is any of this bad or not a problem?
Last edit: 15 Dec 2015 18:51 by emu88.
Time to create page: 1.413 seconds
