Front brakes
  • mickt
09 Dec 2015 17:37 #158188 by mickt
Replied by mickt on topic Front brakes
I got mine from the dealer. Not cheap though!
  • mickt
09 Dec 2015 17:39 #158189 by mickt
Why take a chance of damaging the rad and struggling when you can have the rad out in 10 mins??
09 Dec 2015 17:57 #158195 by Busta
Replied by Busta on topic Front brakes
10 minutes taking off radiator, 10 minutes re-fitting, 20 minutes re-filling and bleeding, old coolant to dispose of and £10 worth of new antifreeze.
Alternatively it takes about 20 minutes to change the belts with the radiator still in place.
  • emu88
10 Dec 2015 00:29 - 10 Dec 2015 00:30 #158210 by emu88
Replied by emu88 on topic Front brakes
Busta wrote: 10 minutes taking off radiator, 10 minutes re-fitting, 20 minutes re-filling and bleeding, old coolant to dispose of and £10 worth of new antifreeze.
Thanks. I already bought new antifreeze though so I'll be draining anyway. What's with the tensioner bearing, should I replace that when I change the belts?
I haven't tried lifting a piston seal to look for corrosion underneath, and didn't know pumping the brake was required to get the piston out further. I'll try. However even if the 'bits that matter' are ok, I'm so fussy I just can't put it back without cleaning everything and greasing and painting!
mickt wrote: And a good days work to. Don't forget to bleed the rear brakes too. There is a nipple on the compensator mounted above the axle. It will be well rusty though!!
Got one ready! Martin had some.
Daniel30 wrote: What will you do after lunch then? :laugh: :laugh: :laugh:
Replace the windscreen seal :P
Last edit: 10 Dec 2015 00:30 by emu88.
10 Dec 2015 08:25 #158220 by Busta
If the tensioner spins nicely there's no need to change it. They tend to start screeching before they fail so you'll get some warning when it is on it's way out. But if you have a press or a decent vice it's pretty easy to change the bearing and they are a standard part from your local bearing suppliers.
  • mickt
10 Dec 2015 11:24 #158224 by mickt
Got what? The compensator or the bleed nipples?
Time to create page: 2.088 seconds
