Front brakes
  • emu88
24 Dec 2015 16:46 #159069 by emu88
Replied by emu88 on topic Front brakes
I've done the calipers, making sure the grooves of all seals are nice and smooth and clean. Does it look like I have done the main seal for the piston OK? If I push the piston back as far as it will go the seals begins to flop over the front of it...
  • mickt
24 Dec 2015 18:13 #159072 by mickt
Replied by mickt on topic Front brakes
I ran the sealant around the kingpin then fitted and tightened the bolts.
The piston only needs to go flush to allow new pads to be fitted and the dust seal looks grand to me.
  • emu88
25 Dec 2015 00:49 #159084 by emu88
mickt wrote: I ran the sealant around the kingpin then fitted and tightened the bolts.
Great! I ran the sealant round the kingpins and the bolt holes too.
Looks like you and I are the only active ones at Xmas :D Have a merry one!
  • emu88
29 Dec 2015 13:42 - 29 Dec 2015 18:38 #159287 by emu88
The long drive shaft had virtually no grease in the CV joint and amongst the ball bearings. Also I notice this play when lightly pulling on the joint. Is this OK, should I just pack with grease and go? I wondered if it might have something to do with the shimmy at 45-50 mph...
Also because the car is on a slight leftwards incline, the axle oil (yellow fluid) drips out slightly. Could that have washed out the grease in the CV joint?
Last edit: 29 Dec 2015 18:38 by emu88.
Time to create page: 0.528 seconds
