Vitara Diff in a Jimny (front) Axle?
- Thank you received: 923
14 Oct 2014 12:19 #126498
Replied by X8GGY on topic Vitara Diff in a Jimny (front) Axle?
That's how he got his name Phil...
Mr. Angry is used when things either won't come off or won't quite fit...!
LOL
Yes, look forwarding to seeing you on the 26th... it's been a while mate!
Dave
LOL
Dave
- Nicks_Jim
14 Oct 2014 18:37 #126526
by Nicks_Jim
Replied by Nicks_Jim on topic Vitara Diff in a Jimny (front) Axle?
Thanks Dave for the photo, i will give it another go at the w/end and check on the amount of grease.Jimny-Dave wrote: Photo just for Nick
Wrote the blog last night, and when I was proof-reading it back I realised I hadn't bent the tab back in when refitting the hub / bearing so had to re-strip it this morning anyway...
Not enough time today though to do the other side, so that will be Sunday now... was hoping to do it sooner, as we're greenlaning next weekend (26th) in the Lake District, so I did want some more time after fitting the LSD / Shafts / CVs i
n case anything goes wrong... time will tell! (all seems ok though?!) :dry:
19 Oct 2014 22:09 #126963
Completed today!
Driver's-side all rebuilt, tie-rod adjust after new rod ends fitted, LSD oil in the axle...
Went round and checked everything was tight, and then test-drove it, and then went to do a local greenlane, had it in 4x4 without the rear (ARB) locked to see how it felt... LSD definitely working drove it up a grass bank to test, and no spinning from the front... will test it in ernest at the weekend, as 'our little group' is up in the Lake District...
Oooo, and the vacuum activated hubs still work as Suzuki intended too!
Many thanks to Martin for his excellent KingPin replacement instructions! Helped a Jimny-spannering-virgin no end
19 Oct 2014 22:11 #126964
How did you get on Nick?
My driver's-side (square-washer and circlip) slipped in just as easy as the passenger-side...
Nicks_Jim wrote: Thanks Dave for the photo, i will give it another go at the w/end and check on the amount of grease.
- Nicks_Jim
20 Oct 2014 19:24 #127019
by Nicks_Jim
Hi Dave, i still had no joy with fitting the circlip,i can pull the shaft out enough to hear it knock up against the hub or so called to fit the circlip on.so i haven't over greased it. james (j999pre) is going to send me some more in the post. as mine are not in very good shapes from previous owner which i'm hoping thats the problem. but if still no joy it looks like i will have to have the square washes machined down or thinner circlips. i will keep you posted. Thanks NickJimny-Dave wrote:
20 Oct 2014 19:32 #127021
Replied by mlines on topic Re:Vitara Diff in a Jimny (front) Axle?
Is the wheel bearing/spindle seated correctly? If the stub comes up against the back of the hub without enough of the shaft end exposed then it sounds as if something is making the hub too fat
Sent from my Nexus 5 using Tapatalk
Time to create page: 1.600 seconds
