Vitara Diff in a Jimny (front) Axle?
- Nicks_Jim
03 Nov 2014 21:17 #128386
by Nicks_Jim
Replied by Nicks_Jim on topic Vitara Diff in a Jimny (front) Axle?
i take it your talking about RS front shafts. why did the cv stub need some work done and why?vdl wrote:
Jimny-Dave wrote: Perhaps the later batches like mine have had any initial teething problems sorted out...?
mine arrived in early august. one cv stub needed some work with lathe. and brake bolts were also a little too long.
- vdl
03 Nov 2014 21:33 #128388
by vdl
Replied by vdl on topic Vitara Diff in a Jimny (front) Axle?
groove in stub was in wrong place - could not fit spacer when assembling hub. made new groove ( 15 eur ) - all fits.
- Nicks_Jim
03 Nov 2014 22:00 #128392
by Nicks_Jim
Hi vdl, i'm sorry to hear that. i'm in the same boat
Hi jimny-Dave, i see there all coming out of the woodwork about the shafts. it looks like you got lucky.vdl wrote: groove in stub was in wrong place - could not fit spacer when assembling hub. made new groove ( 15 eur ) - all fits.
- Thank you received: 923
03 Nov 2014 22:05 #128394
Replied by X8GGY on topic Vitara Diff in a Jimny (front) Axle?
- darthloachie
04 Nov 2014 11:19 #128441
by darthloachie
Replied by darthloachie on topic Vitara Diff in a Jimny (front) Axle?
04 Nov 2014 13:35 #128458
No mate, I spent a good while cleaning the mating faces up with a copper rotary wire brush in a cordless drill, checked and double-checked the fit, and then sealed them together with mastic and tightened the bolts up nice and tight, after adding spring washers under the heads to keep them tight...
It's had one trip out to the Lake District, which was a two hour drive there, a good nine hours 'laning and roads in between, and then a two hour drive back...
Not a spot...
But then there's only grease in there? So not sure how they could 'leak' much anyway?
Unless you mean leaking inwards? water when wading?... :S
darthloachie wrote: any leaks from the spacers Dave?
Not a spot...
