Vitara Diff in a Jimny (front) Axle?
  • darthloachie
04 Nov 2014 13:53 #128463 by darthloachie
Replied by darthloachie on topic Vitara Diff in a Jimny (front) Axle?
Jimny-Dave wrote:
darthloachie wrote: any leaks from the spacers Dave?
No mate, I spent a good while cleaning the mating faces up with a copper rotary wire brush in a cordless drill, checked and double-checked the fit, and then sealed them together with mastic and tightened the bolts up nice and tight, after adding spring washers under the heads to keep them tight...
It's had one trip out to the Lake District, which was a two hour drive there, a good nine hours 'laning and roads in between, and then a two hour drive back...
Not a spot...
But then there's only grease in there? So not sure how they could 'leak' much anyway?
Unless you mean leaking inwards? water when wading?... :S
lol...they all leak inwards!!!!
no I meant grease/gear oil as Russ told me he'd had problems with his HD prototypes leaking
04 Nov 2014 22:23 #128520 by X8GGY
Hmmm, dunno... can't comment on Russ's shafts / CVs as I have no experience of them...
Mine are fine, so far, though... as above, only one trip out so far, but that was a long one with plenty of rough 'lanes...
Will be working on the Jim' tomorrow, so I'll have a lie-down underneath and have a good inspection B)
Time to create page: 1.969 seconds
