Vitara Diff in a Jimny (front) Axle?
  • Bits4Vits
05 May 2014 13:49 - 05 May 2014 13:55 #114199 by Bits4Vits
Vitara Diff in a Jimny (front) Axle? was created by Bits4Vits
I'm sure I've read at some point that Vitara ring and pinnions can be fitted into a Jimny Axle to lower the final drive ratio to correct the gearing for large tyres?
Does anyone know if the actual diff (as pictured below minus the third member / carrier of course) will fit in the front axle of a Jimny?
I've got an ARB air-locker to go in the back of my Jimny build, and am wanting to fit my front LSD (Limited Slip Differential) in the front, which is a Calmini Vitara front LSD, so I'm assuming if the crown wheel and pinnion fit, then the actual diff should fit too?
Jimny shafts are 26 spline?
Thanks in anticipation...
Dave B)
Last edit: 05 May 2014 13:55 by Bits4Vits.
  • bluejimny
05 May 2014 13:54 #114200 by bluejimny
Replied by bluejimny on topic Vitara Diff in a Jimny (front) Axle?
jimny shafts 26 on rear 22 on front
  • Bits4Vits
05 May 2014 13:56 #114201 by Bits4Vits
Replied by Bits4Vits on topic Vitara Diff in a Jimny (front) Axle?
bluejimny wrote: jimny shafts 26 on rear 22 on front
Hi Rus ;)
Shoot! really :(
Buggers that idea up then...! :(
  • bluejimny
05 May 2014 14:08 #114202 by bluejimny
ive never seen a vitara front diff, maybe the jimny 22 spline side gears fit into the vitara diff???
  • Bits4Vits
05 May 2014 14:09 #114203 by Bits4Vits
Ah well, suppose if I've nicked the front ARB from the buggy, I can always fit the LSD into the Calmini Anvil axle destined for it... :unsure:
Only other way is uprated front shafts in the Jimny's front axle then?... they'll be 26 spline?...
Don't really want to go to that expense (yet) though...
  • Bits4Vits
05 May 2014 14:11 - 05 May 2014 14:14 #114205 by Bits4Vits
bluejimny wrote: I've never seen a vitara front diff, maybe the jimny 22 spline side gears fit into the vitara diff???
I suspect they would on an open diff, but as it's an LSD unit the side gears look to be custom shaped to fit in between the clutch plates - www.bits4vits.co.uk/lsdfsm.pdf
Last edit: 05 May 2014 14:14 by Bits4Vits.
Time to create page: 0.273 seconds
