Vitara Diff in a Jimny (front) Axle?
  • Nicks_Jim
21 Oct 2014 19:20 #127130 by Nicks_Jim
Replied by Nicks_Jim on topic Vitara Diff in a Jimny (front) Axle?
Jimny-Dave wrote: Hmmm, this comes back to our PM discussion Nick...
Perhaps the later batches like mine have had any initial teething problems sorted out...?
Hi Dave, maybe your right,but i'll will get to the bottom of it in the end and let u no my out come. Nick
22 Oct 2014 13:13 #127175 by safari
yes twice once he told me to machine down the stub but i thaught i would weaken the stub since it is hardened so i machined the copper in the hub with a sandpaper so th stub could fit . then asked him about the circlip which could not fit ,he told me to leave it without it and agiain i machined it down with the grinder to fit :unsure:
it was not that simple for me to make the swap since the meaturements were not accurate and not a direct swap but happy with the size of cv and shafts
Nicks_Jim wrote: Hi safari, i'm sorry to here that you had the same problem.quest we are not the only ones there be others if we dig deep. did you contact rob storr about it ?
safari wrote: hi i had the same problem when fitting them .only on 1 side i had to machine down the washer tried it on both sides it is is the cv with problem and also had problems with the stubs witch were thicker than the standard ones so first meature them ;)
Nicks_Jim wrote:
Jimny-Dave wrote:
Nicks_Jim wrote: Thanks Dave for the photo, i will give it another go at the w/end and check on the amount of grease.
How did you get on Nick?
My driver's-side (square-washer and circlip) slipped in just as easy as the passenger-side...
Hi Dave, i still had no joy with fitting the circlip,i can pull the shaft out enough to hear it knock up against the hub or so called to fit the circlip on.so i haven't over greased it. james (j999pre) is going to send me some more in the post. as mine are not in very good shapes from previous owner which i'm hoping thats the problem. but if still no joy it looks like i will have to have the square washes machined down or thinner circlips. i will keep you posted. Thanks Nick
if u worry u die if u dont worry u still die so why worry
  • Nicks_Jim
22 Oct 2014 19:54 - 22 Oct 2014 20:05 #127223 by Nicks_Jim
safari wrote: yes twice once he told me to machine down the stub but i thaught i would weaken the stub since it is hardened so i machined the copper in the hub with a sandpaper so th stub could fit . then asked him about the circlip which could not fit ,he told me to leave it without it and agiain i machined it down with the grinder to fit :unsure:
safari wrote: hi i had the same problem when fitting them .only on 1 side i had to machine down the washer tried it on both sides it is is the cv with problem and also had problems with the stubs witch were thicker than the standard ones so first meature them ;) Hi safari, i think yours and mine was from the same batch, i also had problems with other things but i won't go into detail.it looks like he has ironed out all the problems now.
Last edit: 22 Oct 2014 20:05 by Nicks_Jim. Reason: can't see my written post
  • Nicks_Jim
22 Oct 2014 20:03 #127227 by Nicks_Jim
Hi safari, i think yours and mine was from the same batch, as i also had problems with other things but i won't go into detail.but it looks like he has ironed out all the problems now
22 Oct 2014 20:20 #127236 by X8GGY
Nicks_Jim wrote: Hi safari, i think yours and mine was from the same batch, as i also had problems with other things but i won't go into detail.but it looks like he has ironed out all the problems now
From my experience, yes, mine fitted perfectly first time, both sides...
The caliper bolts were too long though, as I mentioned in my own blog ...
So I've spaced them out with a couple of washers until I can get some correct length ones from my fastenings supplier...
  • steffan
22 Oct 2014 21:45 #127251 by steffan
Replied by steffan on topic Vitara Diff in a Jimny (front) Axle?
Why not simply file them down on something like a bench grinder
Time to create page: 1.295 seconds
