Vitara Diff in a Jimny (front) Axle?
- Bits4Vits
14 Sep 2014 21:31 - 14 Sep 2014 21:32 #124123
by Bits4Vits
Replied by Bits4Vits on topic Vitara Diff in a Jimny (front) Axle?
Last edit: 14 Sep 2014 21:32 by Bits4Vits.
- funkyjimny
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
14 Sep 2014 21:38 #124126
by funkyjimny
Replied by funkyjimny on topic Vitara Diff in a Jimny (front) Axle?
Awesome... RAM.... closely guarded secret, watch this space for some awesome kit
- Thank you received: 923
12 Oct 2014 19:06 #126323
Replied by X8GGY on topic Vitara Diff in a Jimny (front) Axle?
Well, some more time has passed, but today I stripped my front axle - steep learning curve when your used to working on Vitaras! - but, at the end of the day... the LSD almost fitted! :blink:
It's never easy is it!
So, after a text conversation with Rockwatt (thanks for answering on a Sunday evening Richard!
) I decided to make it fit...
I noted what was catching where -
And then... yes, you guessed it... Mr. Angry (the angle grinder for those not familiar with my blogs) was called in...
Diff fits! :laugh:
If it don't fit... make it fit! Thanks to some professional machining in the diff by Richard "Rockwatt" Wattam (the God of Gearing), and some hillbilly angle grinding by yours truly, the LSD is now in, pending a rebuild with the new 26 spline shafts and heavy duty (hooge) CVs, from Rob Storr at RS_Mfg !
Diff fits! :laugh:
12 Oct 2014 20:07 #126330
13 Oct 2014 14:33 - 13 Oct 2014 14:37 #126386
The one good thing about being self-employed, is that you can sneak off when you want to... so I gave myself 11-3 off today...
Heading for the shower, but here's a few preview photos... more in my blog later
Fitted the diff after cleaning the axle casing thoroughly (with a magnet and then oily rags)
Popped the shafts in and span the diff's input flange to make sure everything sound well...
Popped the CV on...
Test-fitted the spacer...
Then when I was happy with it, fitted it with mastic between all the faces...
Then, re-assembled... one side for now, will have to give myself some more time off tomorrow then - now I know what I'm doing!
Brakes back on, steering bar and tie-bar with all new rod ends...
Popped the CV on...
Last edit: 13 Oct 2014 14:37 by X8GGY.
- darthloachie
13 Oct 2014 15:11 #126390
by darthloachie
Replied by darthloachie on topic Vitara Diff in a Jimny (front) Axle?
cool
be interested to see if you get any leaks round the spacer as that was the problem Russ was having with his HD cvs
