Front brakes
28 Nov 2015 21:54 #157431
by facade
Replied by facade on topic Front brakes
The seal kit is about £10 a side.
The fluid seal is the square section elastic band. (tbh, if it doesn't look obviously damaged or gone soft it won't leak if you were to use it again, but you shouldn't)
The dust seal (that keeps out muddy salty water) is the big floppy diaphragm, that is held on by the spring clip.
I doubt if you will get that back on if the calliper actually needs a rebuild. They tend to split, let water inside and corrode the piston.
The shop has reconditioned callipers, they are cheaper than the list price, as you get a refund on the old ones, and it saves a lot of fiddling about, but if money is tight, the rebuild kits work out cheaper, especially if the pistons are not corroded so they don't need replacing.
28 Nov 2015 22:00 #157432
Replied by mlines on topic Re:Front brakes
Discs can be back in stock by Wednesday if you want
Sent from my Nexus 5 using Tapatalk
- emu88
28 Nov 2015 22:09 #157433
by emu88
Replied by emu88 on topic Front brakes
Where are the kits available for £10 facade?
Thanks Martin, would the blueprint discs be fine for use with the aisin pads that you stock? I assume all jimnys have the aisin calipers..?
28 Nov 2015 22:20 #157434
Seal kits are here -
www.bigjimny.com/store/caliper-piston-seal-kit.html
Most are aisin, some Spanish were Lucas.
- emu88
29 Nov 2015 10:44 - 29 Nov 2015 12:52 #157458
by emu88
In addition to the seal kits for the calipers, do I need the fitting kit with the metal hardware or can I just reuse the hardware from the existing calipers?
www.bigjimny.com/store/caliper-fitting-k...in-suzuki-jimny.html
Also I cant find any front brake hoses in the store Martin, can you get those in for Wednesday too? I assume I'll need a new left and right one since they seem somewhat corroded onto the calipers.
Replied by emu88 on topic Re:Front brakes
Thank you.mlines wrote: Seal kits are here - www.bigjimny.com/store/caliper-piston-seal-kit.html
Last edit: 29 Nov 2015 12:52 by emu88.
- mickt
29 Nov 2015 20:05 #157518
by mickt
That is only your opinion. I have used WD40 for years and it is just as good as any of the same products. It is a water displacement fluid and it works!
Replied by mickt on topic Front brakes
facade wrote:
emu88 wrote: Hmm ok. Can i reuse the calipers or do they look quite corroded too? If i get new ones i supppse i should get new brake hoses to them too and then bleed the brakes?
Oh, and use a release oil like GT-85, Plusgas or diesel. WD-40 is to spray on your spanners in the drawer to hope that they don't go rusty (Duck oil is better, JL69 is even better)
Time to create page: 2.627 seconds
