Isuzu 1.7 tdi to jimny gearbox
  • Dave cc
01 Feb 2013 12:45 #60532 by Dave cc
Replied by Dave cc on topic Re: Isuzu 1.7 tdi to jimny gearbox
Ok Tom just ran the numbers thru the calculator this is what you will get
Jimny with standard axles and transfer box on 30 inch tall tyres will be doing 58mph at 3000rpm of the engine
Jimny with standard axles and transfer box on 33 inch tall tyres will be doing 64mph at 3000rpm of the engine
Mine is slower (lower geared)as my axle ratio is 4.99:1 against a jimny that is 3.416:1
Ive based this on 3000rpm as to be honset much above that fuel economy will suffer
End of the day its hard to have it both ends of the scale unless you get into 2 speed axles and all that bumf
And driving a jimny on 33s i would say 64mph is fast enough IMO
  • Dave cc
01 Feb 2013 13:02 #60533 by Dave cc
Spoonie my man and follower of all things Derv lol :laugh:
If i can secure this DOHC jimny this weekend then yes there will be a twin cam/Isuzu diesel conversion :)
Price wise i reckon will be around the £550 mark for that you will get a new flywheel converter plate and engine mounts to weld onto jimny chassis.
Can you complete in a week i would say yes will be
Engine out
Cut off jimny engine/chassis mounts
Trim and weld in new mounts
fit adaptor plate
Remove y ring gear from Isuzu and sweat new 1 onto new flywheel done in the wifes oven lol
300tdi Rad may be able to supply some mounts as a extra
You need to turn the turbo compressor housing to face north easily done with a couple of spanners
Will look at making a adaptor to connect jimny exaust as an extra but will probably need welding
Then just leaves the plumbing and wiring all very easy with bits of hose from ebay
Plus all the Tech support you need from yours truly :)
  • TomDK
01 Feb 2013 13:43 #60544 by TomDK
Replied by TomDK on topic Re: Isuzu 1.7 tdi to jimny gearbox
Dave cc wrote: Ok Tom just ran the numbers thru the calculator this is what you will get
All that I get - I think :laugh:
I'm just thinking about the slower running dieselengine. But you're probably right. going any faster on 33's any a lot of fun :laugh:
  • mudman
01 Feb 2013 20:55 #60608 by mudman
Replied by mudman on topic Isuzu 1.7 tdi to jimny gearbox
where did you get your converter plate from??
  • Dave cc
01 Feb 2013 21:14 #60612 by Dave cc
Replied by Dave cc on topic Isuzu 1.7 tdi to jimny gearbox
Made i myself and the flywheel
01 Feb 2013 21:37 #60617 by j999pre
Will there still be a kit for the earlier jimny g13bb?
Grey pick up Jimny
