Isuzu 1.7 tdi to jimny gearbox
  • Dave cc
14 Nov 2012 22:58 #53288 by Dave cc
Replied by Dave cc on topic Isuzu 1.7 tdi to jimny gearbox
Yes i have but have diffrence is i have moved my power steering pump to where the altenator sat with a custom mount then fitted the 80 amp winch aux altenator where the power steering pump was with the origanal altenator above it well way up high out of the mud and water hopethat makes sence :silly:
  • miksyellowsj
14 Nov 2012 23:19 #53291 by miksyellowsj
Replied by miksyellowsj on topic Isuzu 1.7 tdi to jimny gearbox
next question which wires are what on the alternator I couldn't get my to work so plumbed in a sj alternator but it's not very good
  • Dave cc
14 Nov 2012 23:32 #53292 by Dave cc
Not sure as have not wired it in yet but the normal is an exciter wire that comes via the charge light on the dash main charge feed to the battery and as the altenator come from a non electronic controled diesel chances are there is a feed off the altenator that was used to feed a signal to the rev counter via a converter.
If you are running a SJ unit i take it your engine is in a SJ plus without the correct altenator how are you running vacum to your brakes ? My vac pump is on the back of the altenator
  • miksyellowsj
15 Nov 2012 07:52 #53299 by miksyellowsj
no it's in a jimny and I've still Got the old alternator on and running of that so in effect I've got 2 but one I carnt get working I couldn't sort the wires out I've got a replacment of the 1.7 which I'm going to fit and I'm running my power steering from the same side of a vitara made to fit lolbut the sj alternator is tiny
  • Dave cc
15 Nov 2012 10:27 #53305 by Dave cc
What gearbox are you using ?
  • miksyellowsj
15 Nov 2012 12:25 #53310 by miksyellowsj
I'm using the jimny gearbox old type why?
Time to create page: 0.186 seconds
