Stuck in 4wd
- Mattch5150
16 Dec 2018 15:55 #199058
by Mattch5150
Replied by Mattch5150 on topic Stuck in 4wd
I have joined the rubber hose and braided hose with a plastic t piece. No joy, light still flashing and stuck in 4wd. Am stuck now!
- Thank you received: 683
16 Dec 2018 16:03 #199060
Replied by jackonlyjack on topic Stuck in 4wd
I think theirs a filter just below battery should be a blue colour
you may have sucked crap up and blocked it just a thought
- Mattch5150
16 Dec 2018 16:10 #199061
by Mattch5150
I washed that yesterday the tiny little sponge one
?. The pipe s had a metal connector in between them I cut the end of each tube to get it out. Hollow plastic tube in now which is tight. Is the large blue plastic thing a filter too. Btw thanks so much for everyone's help you have all been amazing.
- Mattch5150
16 Dec 2018 16:27 #199063
by Mattch5150
Just a big thanks to all that have helped me. I'm still struggling but at least appear to have found the fault. All I can presume is there is either another split pipe somewhere or a blockage. My plastic t piece to join both tubes seems good but I'm still stuck in 4wd. Is there any way I could drive to the garage even slowly and without turning too tight. Also if I use a syringe on the separated tube would that unlock the hubs. I'm a nurse so have access to some good syringes. Despite my fears last night I do live the jimny, I've done lots on it but this has stumped me. If a garage has a vacuum tester would that help?. Thanks again you are all awesome!
16 Dec 2018 16:32 #199065
Replied by mlines on topic Re:Stuck in 4wd
Its a bit confusing reading your problems. Vacuum issues usually mean it will not go into 4wd. For it to be stuck in 4wd usually points to the transfer box on a vvt Jimny.
However if it is the hubs locked on then simply unbolt them and remove them. You can then drive to the garage
- Mattch5150
16 Dec 2018 16:36 #199066
by Mattch5150
Replied by Mattch5150 on topic Re:Stuck in 4wd
Ok that's good to know. The black hubs with the hex bolts ? You mean.
Thanks
Thanks
Time to create page: 1.020 seconds
