Stuck in 4wd
16 Dec 2018 21:03 #199093 by mlines
Replied by mlines on topic Re:Stuck in 4wd
The flashing light is important beyond just flashing. You need to note the speed of the flash and at what point the flashing starts. It's telling you what the error is
17 Dec 2018 00:28 #199095 by Scimike
Replied by Scimike on topic Re:Stuck in 4wd
If you have not done so already you should try and determine which part(s) are stuck in 4WD.
Jack up any one front wheel, can you turn it by hand and If you can does the front propshaft rotate?
1) Unable to rotate means the wheel hub is engaged and the transfer case is locked in 4WD - not ideal to drive
2) wheel only turns means the front hub is disengaged --good to drive (but check other front wheel is same)
3) wheel turns AND propshaft means that hub is locked but transfer case is disengaged -- good to drive
This should give an idea of which bits have engaged and what action to take to allow your to drive the vehicle. Removing the front prop or manually disengaging the hubs will achieve this whichever you find easy to do.
Think I have this correct and sorry if you have already identified for sure it is stuck.
Mike
17 Dec 2018 05:04 #199097 by Lambert
Replied by Lambert on topic Re:Stuck in 4wd
This T piece of pipe connection you have used, have you blocked off the third branch of it so that even though the two pipes you've connected are joined there isn't an open path to atmosphere?
  • Mattch5150
17 Dec 2018 06:21 #199099 by Mattch5150
Replied by Mattch5150 on topic Re:Stuck in 4wd
Yes done that
17 Dec 2018 10:25 #199105 by Busta
Replied by Busta on topic Stuck in 4wd
Bit late to the party here but some thoughts from reading through:
Check all electrical connections on the transfer case. They may have removed it to do the clutch, and if they didn't remove it they would have had to push the gearbox back against it potentially knocking something.
The vacuum is used to both engage and disengage the hubs, hence the 2 lines to each hub.
You can safely drive it by removing just one hub. You don't need to remove the prop.
The E10 torx bolts on the hub can usually be undone with a regular socket, 8mm I think.
You can remove both hubs, push the collars back and reinstall to put it in 2wd. If you do this, start the car and listen for the hubs engaging (clunk, clunk). If they do, the fault is with the transfer/selector, not the hubs and vacuum system.
Replace any sections of heavily corroded or broken pipes with flexible tubing cable tied to the old steel lines.
Blowing down the pipes will show you if there is still a leak or not.
Check for other issues, like worn wheel bearings. Any movement in the wheel bearing will break the seals and the system will leak.
Landrovers are horrendous to drive and work on. Stick with a Jimny!
  • Mattch5150
17 Dec 2018 14:19 #199106 by Mattch5150
Replied by Mattch5150 on topic Stuck in 4wd
It's in the garage. Just hope they can sort it but not holding my breath!
Time to create page: 0.168 seconds
