Stuck in 4wd
15 Dec 2018 22:30 #199014 by mlines
Replied by mlines on topic Re:Stuck in 4wd
Is this the vvt with the electrically switched transfer box. If the hubs are locking in and out it sounds like the actuator is stuck in the gearbox.
15 Dec 2018 22:57 - 15 Dec 2018 23:04 #199017 by Scimike
Replied by Scimike on topic Re:Stuck in 4wd
Sorry to hear you have a fault on the 4x4 system, but it does sound like its time for you to say goodbye to the Jimny. They are by modern standards a very simple vehicle to work on, it was the main reason I moved away from a 2012 VW Polo TDI in favour of the Jimny. I was happy to see the VW go (very unreliable and expensive to fix), so I understand you have similar feelings about the Jimny.
But back to the fault...
As it worked before it went into the garage for the clutch cable its likely they have disturbed something, but with all vehicle faults not guaranteed. So you could ask them to get it on the ramp and check their work. If it is truly stuck in 4WD (hubs locked) you could remove the front prop shaft and drive it normally, or simply ask the garage you paid to do the work to help (trailer?).
What ever happens hope you find solice in the replacement vehicle whatever you choose.
I can say as a Land Rover owner you dont want one of these if you think the Jimny is unreliable with a unnecessary 4x4 system. By comparison the Jimny is almost "normal", a comfortable little car ! :laugh:
Last edit: 15 Dec 2018 23:04 by Scimike.
  • Mattch5150
16 Dec 2018 07:00 #199023 by Mattch5150
Replied by Mattch5150 on topic Re:Stuck in 4wd
No bad mood yesterday I will be keeping it. Now is front prop shaft easy to get off.? And if I do that I should be able to drive it to garage?. Thanks so much for everyone's help!
16 Dec 2018 08:03 #199024 by Max Headroom
Replied by Max Headroom on topic Re:Stuck in 4wd
Mattch5150 wrote: bad mood yesterday
Hey Matt - that's cool; everyone is allowed a bad mood now and then. :)
Good that you're going to try and hang on to it - there's lots of really willing help here, and I'm sure you will get to the bottom of this problem and have it resolved in no time.
Good luck matey.
16 Dec 2018 08:07 #199026 by mlines
Yes you can drive it without front prop.
I would get them to check the wiring and connector to the transfer box actuator
  • Mattch5150
16 Dec 2018 08:17 #199027 by Mattch5150
Is front prop easy to remove and do I need something to stopoil pouring out?. I will have to do it in near dark!
Time to create page: 0.692 seconds
