Stuck in 4wd
- Mattch5150
16 Dec 2018 14:00 #199051
by Mattch5150
Replied by Mattch5150 on topic Stuck in 4wd
Awesome thanks so much for that. As above I'm under car now. Bolts very tight. Shaft seems to flex as informing. Is it ok to keep forcing them?
16 Dec 2018 14:04 #199052
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic Stuck in 4wd
Yeah, The bolts will be locktighted on. Make sure your spanner/socket is a good fit and lean on them, They will give in the end.
- Mattch5150
16 Dec 2018 14:09 #199053
by Mattch5150
The end of the diff is flexing feels like it would snap if I pull any harder. Does it have to be in gear or anything
16 Dec 2018 14:12 #199054
by Jezz
Yes, Hand brake on and i normally but mine in reverse gear.
- Mattch5150
16 Dec 2018 15:03 #199055
by Mattch5150
After all this. Under car and saw a split pipe. It is the braided one on passenger wheel. Metaljoin tube is rotten.. I'm now try I g to find a hollow tube to join it but no luck so far!!
- Thank you received: 1878
16 Dec 2018 15:47 #199056
Replied by Lambert on topic Stuck in 4wd
Good luck!
Time to create page: 0.691 seconds
