Stuck in 4wd
  • Mattch5150
15 Dec 2018 13:01 #198987 by Mattch5150
Stuck in 4wd was created by Mattch5150
Hi all. The jimny 2005 manual has been working well. It needed a clutch adjustment but cable was seized. Garage fitted a new clutch cable yesterday. When driving yesterday put into 4wd. Car is in 4wd but green light flashing. Will Not go into 2wd or 4l. It was working fine day before cable change. Do you think it is likely connected to cable change. I've checked vacuum pipes,cleaned filter, had wheels off to check hub lines. Checked wires near transfer box. Driving forwards and back but nothing. When I pull black pipe off vacuum port I can hear vacuum when plugging it back in. It Will go back on Monday but cannot drive it far stuck in 4wd. I've jacked wheel up in neutral and it cannot be turned. Very annoying !
15 Dec 2018 13:17 - 15 Dec 2018 13:18 #198988 by Max Headroom
Replied by Max Headroom on topic Stuck in 4wd
Is this the dreaded gearbox wind-up that I've heard about?
I'm sure someone told me that if you can bash it off a kerb or a rock it will jump out of it, but if that's not true I stand corrected.
Worth a try?
...Or a wire has got knocked off a solenoid sw?
Last edit: 15 Dec 2018 13:18 by Max Headroom.
  • Mattch5150
15 Dec 2018 14:12 #198991 by Mattch5150
Replied by Mattch5150 on topic Stuck in 4wd
And garage is 1.5 miles away so driving there is a risk also
  • Mattch5150
15 Dec 2018 15:40 #198993 by Mattch5150
Ive tried the wind up fixes no joy. I presume it had vacuum to put it into 4wd . The switches do absolutely nothing. Wish I had bought a land rover now!!. Thanks for listening all.
  • paradox1001
15 Dec 2018 16:43 #198994 by paradox1001
Replied by paradox1001 on topic Re:Stuck in 4wd
If you pull the vac hoses off won’t that disconnect the front wheels from the drive shafts?
So even though it’s in 4wd you will just be turning the front diff and shafts and not the wheels?
It could then be driven to the garage.
  • Mattch5150
15 Dec 2018 16:55 #198995 by Mattch5150
Replied by Mattch5150 on topic Re:Stuck in 4wd
I'm not sure which hoses to pull off. If driven slowly without tight turns should be ok. Looking for a 4 x 4 panda now
