engine won't start, G16B conversion
29 Apr 2015 12:23 #143409 by mlines
Immobiliser?
The following user(s) said Thank You: GraphicX
29 Apr 2015 15:49 #143416 by facade
GraphicX wrote: tried another cam sensor (had a spare from the G16B which i know is good as i tried it on the jimny prior to swapping engines).
i'm 'fairly' sure the ring is on in the correct position, i had a mechanic fit it & he used a bolt through #1 cylinder spark plug to find true top dead centre on both engines & marked it out. only thing he may have done is possibly gotten it 180° out, but i really doubt it.
You can't get it 180 out on the crank, as the jimny uses a wasted spark system 1&4 and 2&3 fire together. You could get it 180 out on the cam, then it would be 90 degrees out at the crank and it would never run.
Beats me why it even needs a cam sensor in the first place, the crank would be more accurate.
  • suzukisam
29 Apr 2015 16:27 #143418 by suzukisam
Replied by suzukisam on topic engine won't start, G16B conversion
Its got to be the cam pick up ring i just mmarkd mine on 1.3 cam and marked it on 1.6 then pressed back on . Started 1st time get source another 1.3 cam from a jimny j999pre have one ?
29 Apr 2015 20:15 - 29 Apr 2015 20:18 #143431 by Rhinoman
That loose wire is a ground, try connecting it back to the bulkhead. From what I recall the cam sensor should be connected back to a ground connection on the ECU.
Last edit: 29 Apr 2015 20:18 by Rhinoman.
  • Riceye46
29 Apr 2015 21:29 #143433 by Riceye46
Replied by Riceye46 on topic engine won't start, G16B conversion
Have u checked the wires on the big fuse/relay things by the battery mine looked fine but the wire had snapped and couldn't be seen joined it up and fired up worth a try
  • GraphicX
30 Apr 2015 00:59 #143437 by GraphicX
Replied by GraphicX on topic engine won't start, G16B conversion
@ cider; i've pulled #1 & #3 plugs & couldn't get a spark.
@ martin; thought of that, been caught out & about by opening my doors with the key instead of the fob so thought of it pretty quick but not the issue. starter cranks over fine which it won't do if immobilised.
@ facade & suzukisam; that's the stuff that's beyond my knowledge (all the timing etc) so that's why i had it done for me. it's my biggest worry that the ring's in the wrong position & in all honesty seems the most likely. not sure how much trouble it's going to be for me to get hold of another cam, if it comes to it i'll have to hit up the auszooker guys & see if someone is willing to separate from an engine if it comes down to it.
@ rhinoman; last night i ran a wire from that loose lead to the negative terminal on the battery & didn't seem to make any sort of difference. i'm scrounging through the workshop manual you've shared in between working to see if i can see where it goes properly though.
@ riceye; i checked the fuses last night, didn't think to check the wires beneath so will do tonight right after work.
as it stands i'm hoping my friend who's a mechanic will be able to come by again, see if he can see for sure there's no spark at the plugs & look at timing etc, from there if he has no success then i'm looking at getting a replacement cam with ring in place it seems, if it doesn't start with that as well i'm pretty much out of luck it feels =(
Time to create page: 0.389 seconds
