Stuck in 4wd
19 Dec 2018 23:41 #199208 by sniper
Replied by sniper on topic Stuck in 4wd
Two hours labour to change my transfer box today, mine failed to recognise engagement of 4L.
A switch fault I believe, as it moved to 4H with no issue and when moved to 4L, you could hear the actuator engaging but it timed out.
I had an exchange box that had known history, it solved my problem.
It was my intention to change the switch and sell the box on, once tested. It should be good for £300 after me spending £100ish on the work.
If you want to buy it as is, to either fit your box's 4L switch to and fit, or remove the actuator, for your box, Let me know.
sniper
  • Mattch5150
22 Dec 2018 17:55 #199317 by Mattch5150
Replied by Mattch5150 on topic Stuck in 4wd
I've looked for free hubs on store but cannot find them.. Any ideas on price for hubs and fitment kit? There seem to be ones on ebay too cheap for my liking!
22 Dec 2018 18:12 #199318 by j999pre
Replied by j999pre on topic Stuck in 4wd
I sell manual hubs £100 new
Grey pick up Jimny
  • Mattch5150
22 Dec 2018 18:19 #199319 by Mattch5150
Awesome, when I'm ready ill message you, cheers
Matt
  • Mattch5150
24 Dec 2018 14:14 #199396 by Mattch5150
The jimny is also in the habit of kangarooing in any gear , intermittently. Is this highly likely to be crank sensor?, i believe its quite common on vvt?
  • Mattch5150
26 Dec 2018 09:35 #199451 by Mattch5150
Hope all had a good Christmas. Jimny is off to garage tomorrow. I need to confirm if actuator is broken and if so will put a new one on. All I am thinking is at the .moment the green light is not flashing so does that mean that there is no vacuum leak? as if so it would flash? Or would it only flash after attempting to engage 4wd. ?
Time to create page: 0.462 seconds
