so what do guys want ?
- suzuki jimny fella
- Visitor
blakey2000 wrote: i don't see why you would want an unsprung wheel on the ground with dislocating springs it would still have no traction as there is no force pushing it down. making it fairly useless like a wheel in the air.
besides having the look at my awesome gap between my wheel and arch feel.
i cannot see the point of it. Unless there is something else there to push the wheel down to have traction like a second spring.
One benefit being that you will achieve better articulation with a minimal lift. I'd want it on a 2" lift to keep the COG low.
While the wheel on the uncompressed side will have less weight on it there is still a force applied, where one wheel is being forced up it will provide a downward force on the opposing side, just enough to get you through.
I'd have 2" lift springs and +3"(hypothetically) dampers with dislocation.
- Dutchjimny
- Visitor
- reaper
- Visitor
Something im working onsuzuki jimny fella wrote: bolt on diff guards
- Rockwatt
- Visitor
Dutchjimny wrote: Something that will really cure the deathwobble maybe a nice switchpanel
Set the kingpin bearings to the correct preload and when fitting bigger tires correct the scrub radius with the right size wheel spacers or wheel offset.
Switch panel ! Where do you want it to fit ? Size ? How many switches ?
- reaper
- Visitor
- Rockwatt
- Visitor
Turbo would be more use ! And more controllable !reaper wrote: As it seems a waste of your tallent to request trivial things how about a tru bolt on supercharger ?
There not my thing but I know a man who can. And if there was enough interest then a kit could be developed.
But as the old saying goes there is no substitute for cubic inches.
So stick a 1.6 or 2.0 ltr in there and save some money into the bargain.
Vitara 1.6 16v with it's gearbox and dual transfer case would be spot on for the jimny IMO
- Mumbo Jimbo
- Visitor
- Black Toy
- Visitor
My suggestion is a bar for mounting roof lights...
- blakey2000
- Visitor
this might help you, www.bulletcars.com/superchargers/suzuki/ a company here in Australia, Queensland, already have a bolt on super charger kit. but does require a piggieback ECU to work. as id say any turbo or supercharger kit will need. unless you can get a hold of a already turbo jimny ECU from japan
- viciouspenguin
- Visitor
blakey2000 wrote: this might help you, www.bulletcars.com/superchargers/suzuki/ a company here in Australia, Queensland, already have a bolt on super charger kit. but does require a piggieback ECU to work. as id say any turbo or supercharger kit will need. unless you can get a hold of a already turbo jimny ECU from japan
Hello supercharger. I wonder how I can get £5000? hmmmmm......
- myers647
- Visitor
james
