so what do guys want ?
- adamjimny
- Visitor
sent from my Samsung Galaxy S2 using Tapatalk
- darthloachie
- Visitor
wide angle hd propshafts with multi-fit end flanges for use with rocklobsters and big lifts
multi fit - two sets of holes (like on aftermarket alloys) for the transfer box end that will fit either 410 or 413
- Thank you received: 584
oxford_bloke wrote: smoggy,
as far as anti roll bars go, take it of grind down the brackets and it will pass. i have done this on a couple of cars and taken it to strict MOT places and no isssues at all they can only fail what is there not what isn't
tom
Bad advice I'm afraid. If it left the factory with one fitted it will fail if it doesn't have one when presented.
2012 Testers Manual Section 2.4 G
Reason for failure
"A suspension component or its attachment bracket or linkage:
missing where one is fitted as standard"
Same thing for steering locks
Airbags
Belt pretensioners
However, you are allowed to remove the entire ABS system if you like.
- Rockwatt
- Visitor
Alternator mount, to add
Flex radius arms + spring dislocation , already in development. fully bolt on
Uprated tie rod, to add
Multi hole transfer flanges, my Sj cases come with then as standard
wide angle props, already do them. Custom to order.
Alloy tree sliders, do you mean like the landy type ? Just below window line !
Anti roll bar disconnects, to add
Diesel conversion. Not to add. To many engine choices, to many variables in the engines. To cover them I would need to fit about 30 different engines just to get a kit that was anywhere near universal. There is also radiators. Intercoolers, Fuel tanks, reduction starter motors ,
IMO the only engine that comes close to a suitable weight for a Jimny is the zuzu lump and not many people want to use them, preferring the pug/vw lumps.
Anything else ?
- jo king
- Visitor
- Rockwatt
- Visitor
No problem ! How about a pair of atomic axles instead (google it )jo king wrote: Yes purpose built bolt on fitment of a pair of portal axles with electric locking diff and low geared to fit a standard jimny using standard springs. All for under 2k or cheaper.
You have got to be jo king wah hah hah
- blakey2000
- Visitor
besides having the look at my awesome gap between my wheel and arch feel.
i cannot see the point of it. Unless there is something else there to push the wheel down to have traction like a second spring.
- viciouspenguin
- Visitor
Oh snap!
Check out them badboys.
- bluejimny
- Visitor
Oh snap!
Very Nice!!!
- toph
- Visitor
Rockwatt wrote: Thanks for the Feedback.
They're the ones, boring bolt on item I know.
- bluejimny
- Visitor
blakey2000 wrote: i don't see why you would want an unsprung wheel on the ground with dislocating springs it would still have no traction as there is no force pushing it down. making it fairly useless like a wheel in the air.
is a good point, simon and Xeng does something like that for the LR a spring within a sping
- Rockwatt
- Visitor
Try doing something like this without it. wheels on the ground = stabilityblakey2000 wrote: i don't see why you would want an unsprung wheel on the ground with dislocating springs it would still have no traction as there is no force pushing it down. making it fairly useless like a wheel in the air
One of many failed attempts at the same gully.
