so what do guys want ?
- markyp2000
- Visitor
facade wrote:
oxford_bloke wrote: smoggy,
as far as anti roll bars go, take it of grind down the brackets and it will pass. i have done this on a couple of cars and taken it to strict MOT places and no isssues at all they can only fail what is there not what isn't
tom
Bad advice I'm afraid. If it left the factory with one fitted it will fail if it doesn't have one when presented.
2012 Testers Manual Section 2.4 G
Reason for failure
"A suspension component or its attachment bracket or linkage:
missing where one is fitted as standard"
Same thing for steering locks
Airbags
Belt pretensioners
However, you are allowed to remove the entire ABS system if you like.
ifi your car is highly modifiyed you dont need
steering locks
Airbags
Belt pretensioners and many other things
- reaper
- Visitor
- markyp2000
- Visitor
front drivers seat dont have to move and lock in possition steering locks can be removed air bags and meny other thing and what has the dvla got to do with it
- Dave c
- Visitor
Rockwatt wrote:
yes a resigned suspension "system" is on the cards. And it won't just be a set of caster correction arms. But it will be strictly offroad only!kirkynut wrote: So you have suspension under development then Richard?!? I might hold off on buying any castor corrected arms and see what you're suspension's all about then! Do you have any time scale on it being ready?
If you still have my number give me a call :wink:
Ah Poo - for off road only! I understand why though with the cost of product liability insurance etc and making stuff that works off road work well enough on the roads when the two diciplines are at odds with each other!
Not to worry - I will keep an eye out for when your website goes live though - post on here when it does to save us all keep trying to access it if you can though please Richard! I'll then see what else you have going on!
markyp2000 wrote: not acording to the mot meating i went on at the start of the year if used for race and has to be road leagle for safety resons
I think he means VOSA who are ever present at the side of the roads these days!
What did they say if the vehicle is not used for race of competition though and is just for playing like wot I does - how should the tester view it then?
Some of these rules are starting to get to be a pain in the back side!!!
Just wondered if you are any closer on deciding which ideas you can take forward, or which are even viable?
- Rockwatt
- Visitor
I'll be attacking most of them even the wheel arches but over the next few months I'll be moving and building a custom built workshop. So I'm in limbo for a little while.Obarno wrote: Hi Redacted
- markyp2000
- Visitor
Kirkynut[/quote]
alright then modified for offroad/race use but need to be road legal in other ways
- Thank you received: 210
+ brackets that bolts on to the chassis with holes drilled, for the front and back pan hard rods from 2" to 3" so you can use the original rods as fitted to Panosd jimny.
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
- markyp2000
- Visitor
- blakey2000
- Visitor
