Jimny Owner - Encountered 1st Problem 4x4 - HELP!
16 Apr 2016 21:24 #165426
by Busta
Replied by Busta on topic Jimny Owner - Encountered 1st Problem 4x4 - HELP!
You need the engine running to select 4wd, otherwise there is no vacuum to engage the hubs!
- alix4x4
16 Apr 2016 21:26 #165427
by alix4x4
Replied by alix4x4 on topic Re:Jimny Owner - Encountered 1st Problem 4x4 - HELP!
I was just checking if it changed without starting.
Even when started it doesn't engage.
- Barkis21
16 Apr 2016 21:37 #165428
by Barkis21
Replied by Barkis21 on topic Jimny Owner - Encountered 1st Problem 4x4 - HELP!
Get under the car on the bottom of transfer box nearest to the front you will see a blue/black round part with two wires coming out of it check them properly as mine looked intact from looking under at the side or the car on of mine was just hanging on by the insulation I reconnected it tried 4wd no issue at all now
- alix4x4
16 Apr 2016 21:39 #165429
by alix4x4
Ok thanks. Will have a look...
- alix4x4
17 Apr 2016 15:39 #165447
by alix4x4
Replied by alix4x4 on topic Jimny Owner - Encountered 1st Problem 4x4 - HELP!
Does the small rubber air filter cause it not to select 4wd?
I says if clogged it won't select mine is broken. Iv just found all the rubber is perished. This is from the front under bonnet near vacuum valve I think it's called
- alix4x4
17 Apr 2016 16:21 #165449
by alix4x4
Time to create page: 0.173 seconds
