Jimny Owner - Encountered 1st Problem 4x4 - HELP!
  • alix4x4
14 Apr 2016 18:03 #165335 by alix4x4
Hi Guys, Apologies that my 1st post is a advice/problem post!
Recently purchased a 2006 Suzuki Jimny for the other half,
Now I have nothing to compare against so Im hoping someone on here will have similar year/car and will know what my car should be doing...
Basically, on standstill when I select 4wdH (the middle button) I get a constantly flashing green light - And I can hear something engaging HOWEVER, As soon as I select 1st gear there is a loud noise from the centre of the car like a grinding sound and it will not move when the clutch is lifted - NOISE occurs when I try setting off...
Then to reselect 2wd by pushing the button doesn't work unless I switch off the engine and then press the button - they it will make a psss/air release sound and go back into 2WD.
Drives perfect on 2wd,
and when I select 4wd-L from 2WD all i get is 3 beeps with no light on the dash...
So guys, sorry that my first post is a problem post - but this is really driving me nuts as Im not sure if something is wrong or if im doing it incorrectly....
any help appreciated
14 Apr 2016 18:51 - 14 Apr 2016 18:52 #165338 by gilburton
This might help but please note you cannot use 4wd on tarmac or you may cause damage. It's only to be used on loose/slippery surfaces such as snow/gravel/mud.
I started off high and worked my way down ever since :-)
Last edit: 14 Apr 2016 18:52 by gilburton.
  • alix4x4
14 Apr 2016 20:58 #165339 by alix4x4
Hi. Thanks for that link.
I understand that the surface I'm parked on is hard however when I select 4wd the light just keeps on flashing and doesn't stay on??
14 Apr 2016 22:09 - 14 Apr 2016 22:11 #165340 by gilburton
Have you tried moving slowly and pressing the 4wd button?
The flashing light means it's not engaging.
Last edit: 14 Apr 2016 22:11 by gilburton.
  • alix4x4
14 Apr 2016 23:43 #165343 by alix4x4
Yes I have pressed the button and when I move off slowly there seems to be a loud grinding sound from under the car, and when i dip my clutch the noise goes away...
Thats what I think too - it isn't engaging....
15 Apr 2016 07:45 - 15 Apr 2016 07:47 #165346 by gilburton
Just to confirm you are using the clutch when selecting 4wd??
Make sure you push it to the floor as it has a switch.
When I said try moving slowly I meant as you select 4wd not moving away.
It has been known that if the mechanicals aren't quite lined up by moving a little everything engages.
Drive in a straight line at less than 50mph (preferably slower) and dip the clutch(leaving it in gear) and try engaging 4wd.
If you can find a gravel car park or similar it might make it easier.
Anyway if after all this the light still flashes then you have a problem.
Chances are it's nothing more than the connectors on the transfer box.
If 4wd hasn't been used for a long time like most things electrical they can stop working.
If you can get underneath you will see some connectors just unplug them a few times and check for anything obvious.
Last edit: 15 Apr 2016 07:47 by gilburton.
Time to create page: 0.346 seconds
