tow bar
25 Aug 2015 08:00 #150570 by gilburton
Replied by gilburton on topic tow bar
The Jimny is "old school" there are no plug in connectors and you have to break in to the rear loom.
You could solder the connections and use heat shrink sleeving if you don't want to use the Scotch method.
I started off high and worked my way down ever since :-)
25 Aug 2015 08:15 - 25 Aug 2015 08:19 #150576 by facade
Replied by facade on topic tow bar
When I had a Rangerover, you took one of the rear lights out and there was a dedicated connector to plug the (£100) genuine harness into, so you simply scotchloked to those wires. (They kindly brought the other indicator to that side for you)
There is a Suzuki plug in harness available 990E0-84A21-000 , I imagine it fits like the one for my Other Car, you unplug all the lights, and the harness comes with sockets that take the plugs to the lights, and plugs that then go to the lights.
I didn't buy one for The Other Car, as you had to take the whole car apart, to run wires to the connectors for each light, I had to do that anyway, and it was about £80.
Last edit: 25 Aug 2015 08:19 by facade.
25 Aug 2015 09:11 #150578 by j999pre
Replied by j999pre on topic tow bar
There is a connector or connectors deepening on year that is undernear side rear light. It's a bumper off job to get to them
Grey pick up Jimny
  • Brooklynodog
25 Aug 2015 18:36 - 25 Aug 2015 18:37 #150611 by Brooklynodog
Replied by Brooklynodog on topic tow bar
"Simple" job getting more complicated, lol. Bar I have bought does not require bumper removal, but if there is a connector there it would be worth it. How hard is it? I was disapointed to discover there is no Haynes manual for the Jimny by the way. Mine is 56 (07) JLX VVT
Last edit: 25 Aug 2015 18:37 by Brooklynodog.
  • gusthegorilla
25 Aug 2015 19:14 #150614 by gusthegorilla
Replied by gusthegorilla on topic tow bar
You, and hundreds more :sick:
About all there is available without spending zillions is a £5 CD off ebay....not bad, but certainly not Haynes :whistle:
Gus :)
  • wombat
25 Aug 2015 20:11 #150620 by wombat
Replied by wombat on topic tow bar
Hi, even though the towbar you have bought says bumper removal not needed you will find it easier and quicker to remove the bumper and also to wire it up :)
Time to create page: 0.216 seconds
