tow bar
  • Brooklynodog
11 years 3 months ago - 11 years 3 months ago #149931 by Brooklynodog
tow bar was created by Brooklynodog
Can anyone plesse advise me on simplicity or otherwise of DIY fitting of tow bars please?
Last edit: 11 years 3 months ago by Brooklynodog.
  • gusthegorilla
11 years 3 months ago #149932 by gusthegorilla
Replied by gusthegorilla on topic tow bar
  • Brooklynodog
11 years 3 months ago #149933 by Brooklynodog
Replied by Brooklynodog on topic tow bar
Thanks, thats helpful, presumably other makes use the pretapped holes as well? Would prefer a detachable ball. How complicated are the electrics?
  • gusthegorilla
11 years 3 months ago - 11 years 3 months ago #149935 by gusthegorilla
Here's another one for ya ;) www.bigjimny.com/images/documents/jimny_towbar_install.pdf
Gus :)
PS Personally, I think Scotchlocks are crap...much better methods are available.
Last edit: 11 years 3 months ago by gusthegorilla.
  • wombat
11 years 3 months ago #149945 by wombat
Replied by wombat on topic tow bar
Hi, took me an hour to fit mine, but two hours to wire it up !!
  • gilburton
11 years 3 months ago - 11 years 3 months ago #149951 by gilburton
Replied by gilburton on topic tow bar
All the different makes use the same holes.
They are not pre tapped what you are seeing is a nut on a long tab that is inserted into the open end of the chassis.
As stated it's quite easy to fit but put everything in place LOOSELY until every nut/bolt/bracket is attached then tighten it all up.
The electrics can be difficult if you go the method of removing the n/side interior trim as it can take a while to get access.
Once there the loom is very accessible (as in the pics)
If you take off the rear light lenses you can see which colour wires go where.
There are no electronics to worry about as the Jimny is an older design.
You can cheat on the wiring by tapping in to the rear lights etc. it just depends on what or how much you can do.
If you do take the n/s interior trim off it would be worthwhile doing the rear speakers at the same time as the wiring and holes for speakers are there but you'll also need to take off the o/side trim as well..
You can see the small white squarish connector in one of the pics. just in front of the scotch clips.
2x 4" (100mm) speakers and some speaker wire is all you need.
Last edit: 11 years 3 months ago by gilburton.
Time to create page: 0.098 seconds
