Jimny bits 2" lift
  • reflexsa
22 Jul 2014 19:38 #120499 by reflexsa
Replied by reflexsa on topic Jimny bits 2" lift
TomDK wrote:
funkyjimny wrote: I've had Jimnybits 3" springs on a couple of cars now and always been pleased with them, ProComp shocks I've had no bother with for the last 10 years of jimny ownership, I've had ES1000's, 3000's, and also 9000's, depends on your car useage, sounds like you'll want 1000's. The rear shock re locators stop the bottom shock bush from wearing out in 5 minutes, when you lift the car it increases the angle of the rear shock bolt.
Gary
Wears out in 5 minutes? Who told you that?
These relocators are a waste of money if you ask me, and with them installed these a bigger risk of you shocks bottoming out, with damage to follow.
So no, you do not need shocks relocators.
I was wondering about the bottoming out. If you hit the damper before the chassis endstop I think you will cause some proper damage.
Yeah I'm not sure why they are so recommended. Pretty much every kit here the guys just put the shocks straight on :-/
  • TomDK
22 Jul 2014 19:47 #120500 by TomDK
Replied by TomDK on topic Jimny bits 2" lift
reflexsa wrote:
Gary
Yeah, at best they're just a waste of money.
Just remember no matter what suspension lift you put on, to check if your bumpstops are long enough. Fit the shocks w/o spring and check with full compression.
  • bluejimny
22 Jul 2014 20:34 #120508 by bluejimny
Replied by bluejimny on topic Jimny bits 2" lift
so far we have only had good reports from customers who have had the AVO shocks, 80% of them go to Australia
we have sold over 3000 ES1000 shocks so cant be that bad
22 Jul 2014 20:41 #120509 by funkyjimny
Replied by funkyjimny on topic Jimny bits 2" lift
Gary
Tom, I've been driving modded jimnys for 10 years, I've had 6 in that time, I drew the original design for shock relocators on a fag packet 9 years ago to alleviate the problem of rear shock lower bushes destroying themselves in no time on lifted jimnys where the rear axle has rotated due to the lift. Shocks bottom out when you fit shocks of the wrong length, if you fit rear shock brackets take that into account when purchasing your shocks.
Gary
  • supergaz
22 Jul 2014 21:10 - 22 Jul 2014 21:11 #120514 by supergaz
Replied by supergaz on topic Jimny bits 2" lift
I'd go with Jimnybits lift kit, I've a 3" lift kit with Pro comp ES3000 on my very heavy jimny and the ride is excellent. With a less heavy jimny i'd have got the ES1000
Last edit: 22 Jul 2014 21:11 by supergaz.
22 Jul 2014 21:16 - 22 Jul 2014 21:20 #120515 by Rhinoman
Replied by Rhinoman on topic Jimny bits 2" lift
I have the Jimny Bits 2" springs and they are a fairly good ride with good flex I got the springs used and fitted Rough Country shocks from the BigJimny shop. Having measured up all the clearances at the rear I can say that the shock length supplied by JB (he emailed me the details) is spot on without the extensions and the bump stops will be hit before the springs fully compress without the shocks bottoming out. I haven't measured up the front yet, I'm running extensions and saving up for new shocks.
Last edit: 22 Jul 2014 21:20 by Rhinoman. Reason: corrected JB/BJ
