Waxoyl
- jimnyturbo
Tadpole wrote: Any thoughts on 'Clear or 'Black' ..........
TO tell the truth the black aint that black, when sprayed on non black surfaces, but give you a clue where you did spay it :S
- jimnyturbo
helijohn wrote:
That's a good idea.jimnyturbo wrote: if your motor is a smoker bang some slick 50 in it, its amazing stuff and swear by it... stuck some in mine when i did the oil change, and the engine is noticeably quieter ..
it only smokes on startup (like a coal power station chimney) so I think it is oil seeping into the cylinder(s) overnight and I don't know if Slick 50 will fix that - what do you think?
not sure if anything would fix it m8, but slick 50 is worth a try
It's going out of sight in box sections so could be any colour I guess; if they did a discount for pink I'd use that..........when it gets done. I might drop the motor if it fails the MoT.
On the driver's side I opened out the middle lug hole and made another hole farther back so leaving two lug holes intact. As far as the sills go I am ready to inject the fluid.
facade wrote: There are access holes under the edge of the carpet with large plastic bungs in them.
They turned out to be ideal thanks. I am happy now as I have coated inside the inner and outer sill.
- Sandspider
Cheers.
