Waxoyl
- jimnyturbo
24 Jun 2013 16:37 #74894
by jimnyturbo
Replied by jimnyturbo on topic Waxoyl
No eBay APP ID and/or Cert ID defined in Kunena configurationif your motor is a smoker bang some slick 50 in it, its amazing stuff and swear by it... stuck some in mine when i did the oil change, and the engine is noticeably quieter ..
on a worn engine slick 50 takes up the wear by bonding itself to everything in your engine, and helps mpg, helps to stop smoky engines, and make starting easier too, due to less friction... worth a try m8... got mine here, cheapest price i could find it at.. £16.50 including postage
- jimnyturbo
24 Jun 2013 16:39 #74896
by jimnyturbo
No eBay APP ID and/or Cert ID defined in Kunena configurationand instead of waxoyl i used this
24 Jun 2013 17:48 #74919
it only smokes on startup (like a coal power station chimney) so I think it is oil seeping into the cylinder(s) overnight and I don't know if Slick 50 will fix that - what do you think?
Replied by helijohn on topic Waxoyl
That's a good idea.jimnyturbo wrote: if your motor is a smoker bang some slick 50 in it, its amazing stuff and swear by it... stuck some in mine when i did the oil change, and the engine is noticeably quieter ..
24 Jun 2013 17:50 #74920
Why??
I use that in underseal. I am betting they are all much the same TBH.
jimnyturbo wrote: and instead of waxoyl i used this
Why??
- Tadpole
24 Jun 2013 17:53 #74922
by Tadpole
Replied by Tadpole on topic Waxoyl
Any thoughts on 'Clear or 'Black' ..........
24 Jun 2013 17:56 #74925
Clear every time. That's instinct kicking in, not logic. Black would be better cos you can see if it is there. Clear would be better cos the drips can't be seen. lol
Tadpole wrote: Any thoughts on 'Clear or 'Black' ..........
Time to create page: 0.162 seconds
