Hub nut tool
12 Mar 2014 08:39 #108269 by maverick
Replied by maverick on topic Hub nut tool
TomDK - do you have a similar trick to put the bearing/collar on the rear half-shaft ... I suspect :( that the half-shaft is a little to big for my oven!!
Jalapeño, IISY?
  • idiotmobil
12 Mar 2014 08:55 #108270 by idiotmobil
Replied by idiotmobil on topic Hub nut tool
And tge bearing push in ok with a good sized vise
  • Bigjim91
12 Mar 2014 09:31 #108276 by Bigjim91
Replied by Bigjim91 on topic Hub nut tool
Chrz me n a mate are goin to have a crack at it this morning
12 Mar 2014 10:51 #108283 by kirkynut
Replied by kirkynut on topic Hub nut tool
maverick wrote: TomDK - do you have a similar trick to put the bearing/collar on the rear half-shaft ... I suspect :( that the half-shaft is a little to big for my oven!!
You'd need to put the half shaft in the freezer but still, unless you have a bloody big chest freezer you'll not be able to!
I have access to a mates fly press, on which I did mine on Saturday as it happens, or my father in law has a hydraulic press I used last time.
  • Bigjim91
12 Mar 2014 14:03 #108295 by Bigjim91
Wheel bearing completed, took us 2 1/2 hours, using hammer and punch and a bottle of gas just needed a little heat, a local garage pressed out the old bearing casing n put the new one in for a £10, can go plugging tomoro now! :)
  • gipcyan bill
12 Mar 2014 16:19 #108308 by gipcyan bill
Replied by gipcyan bill on topic Hub nut tool
Keep an eye on the bearing
Wacking it with a hammer is no were near inuff tight
Time to create page: 0.271 seconds
