Fitting my remote central locking/alarm unit
  • helijohn
17 Oct 2013 22:34 #86783 by helijohn
No eBay APP ID and/or Cert ID defined in Kunena configurationReplied by helijohn on topic Fitting my remote central locking/alarm unit
410shotgun wrote: that's the way I did it but did not use the bracket on the motor drilled the door just up a bit than you have and put the rod up the door lock knob rod and fixed it with the clamp that came with the motor
than ran a twin flex across the door and in to the cab
Here's why I didn't mount the actuator higher up; mainly I liked the access at the hole, as I recall the door lock that was there was in the way of mounting it vertically and finally the rod was just the right length at that position. It would make for a quicker job if you don't use a bracket.
Did you pass your wire through the rubber sleeving that the existing harness passes through.
  • 410shotgun
18 Oct 2013 10:51 #86828 by 410shotgun
No eBay APP ID and/or Cert ID defined in Kunena configurationReplied by 410shotgun on topic Fitting my remote central locking/alarm unit
yes ran the flex through the rubber sleeving or boot
  • helijohn
18 Oct 2013 17:56 #86890 by helijohn
All finished now and for the money it is excellent.
  • 410shotgun
18 Oct 2013 20:40 #86937 by 410shotgun
that's good to hear
  • helijohn
19 Oct 2013 09:20 #86993 by helijohn
410shotgun wrote: that's good to hear
Except it has a feature that is driving me nuts. It is called "Warning for temporarily parking car". The direction lights flash for 8 seconds every single time I open the door. Not only does the tick tock irritate me but it means I can't jump in and drive of from a parked position in the high street. Also I am forever opening and shutting the door to fiddle with the motor so it is tick-tocking for hours which can't be good for the battery.
I think I may have to disconnect the flashers from it which is a pity. :( There is nothing else I can do about it. If these alarms are all like this I would not automatically recommend one and that's a turn about isn't it.
  • helijohn
19 Oct 2013 17:18 #87053 by helijohn
Drove me mental so sadly disconnected the flasher leads from the unit. It still clicks away but ear plugs will cure that. :angry:
Time to create page: 0.276 seconds
