Fitting my remote central locking/alarm unit
  • helijohn
20 Oct 2013 14:24 #87189 by helijohn
No eBay APP ID and/or Cert ID defined in Kunena configurationReplied by helijohn on topic Fitting my remote central locking/alarm unit
Yet another installment added to the first post.
  • jonesyba420
20 Oct 2013 15:28 #87201 by jonesyba420
No eBay APP ID and/or Cert ID defined in Kunena configurationReplied by jonesyba420 on topic Fitting my remote central locking/alarm unit
Mine re arms if you dont turn the ignition on as it should, this is incase you accidently unlock it while walking away from the vehicle.basicaly when you turn the key the alarm obviously knows your in the car so wont re arm, if you dont turn the key it assumes your not inside and relocks.
Atleast youve got it sorted to your satisfaction now mate.
  • helijohn
20 Oct 2013 16:19 - 20 Oct 2013 16:20 #87205 by helijohn
jonesyba420 wrote: Mine re arms if you dont turn the ignition on as it should, this is incase you accidently unlock it while walking away from the vehicle.basicaly when you turn the key the alarm obviously knows your in the car so wont re arm, if you dont turn the key it assumes your not inside and relocks.
I want to add a pin switch to the bonnet and I need to reconnect the door courtesy light with an override for turning it off when it annoys me.
Last edit: 20 Oct 2013 16:20 by helijohn.
  • jonesyba420
20 Oct 2013 16:28 #87206 by jonesyba420
Mines came with a pin switch for the bonnet which is fitted and essential. The siren on my system has a built in power source so if you disconnect it the siren sounds and can only be turned off with a key.
20 Oct 2013 20:25 #87252 by jimkyx
No eBay APP ID and/or Cert ID defined in Kunena configurationReplied by jimkyx on topic Fitting my remote central locking/alarm unit
helijohn wrote: Drove me mental so sadly disconnected the flasher leads from the unit. It still clicks away but ear plugs will cure that. :angry:
With the flasher leads disconnected how do you know the system has armed?
  • helijohn
20 Oct 2013 20:57 - 20 Oct 2013 21:04 #87261 by helijohn
Siren goes chirp - literally sounds like a demented Robin. Also there is the visual on the door pins.
BTW, the flashers are now connected again. I took the door switch lead off and connected the given lead for the acc. side of the ignition switch. You have to have one or the other (door switch or acc. switch) to stop the alarm from re-arming.
Incidentally I am going to reconnect the courtesy light switches to the brain with an interruptor switch after I install a pin switch in the bonnet.
Last edit: 20 Oct 2013 21:04 by helijohn.
Time to create page: 0.482 seconds
