Body lift
  • X8GGY
26 Dec 2020 18:24 #231210 by X8GGY
Replied by X8GGY on topic Body lift
"Where there's a will, there's a way" ;)
26 Dec 2020 19:45 #231214 by Mike G
Replied by Mike G on topic Body lift
Let's hope so. I admire the optimism. Just hoping it's not too far gone.
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
27 Dec 2020 11:27 #231226 by Roger Fairclough
Replied by Roger Fairclough on topic Body lift
Use a suitable powered wire brush to remove all the corrosion. Shock treatment ie thump with a lump hammer ( don't go overboard ) usually helps. If possible reshape hex. with angle grinder. If this is possible try suitable single hex. socket with loosen/tighten motion to further break bond. Use heat only if sure you wont set fire or damage something. Windy gun not advised as can be to abrupt. You want to build up torque level to just enough. There are specialist sockets (refer google outlets ) that are designed for this situation. Mole grips and pipe grips are other possibilities.
Roger
27 Dec 2020 12:04 #231228 by jackonlyjack
Replied by jackonlyjack on topic Body lift
Like Lambert says wd40 or similar 2 to 3 time a day over a few days
Wire brushing occasionally
I have removed them from 2001 and 2004 slow and steady
Loosen tighten wire brush some copper slip grease and repeat ;)
  • X8GGY
27 Dec 2020 15:49 #231237 by X8GGY
I got mine off on the Boogie, the buggy's donor is a 1999 and they came off eventually to get the JimnyBits sidebars on as they mount to the chassis rail in the middle and the four body mounts either side and under the doors...
I replaced the nuts as a matter of course...
27 Dec 2020 17:34 #231241 by Mike G
there we go, that's the state of them. Some are likely to need replacing and theres a fair bit of welding to do on the body, including sills and slam panel. Chassis will be ok, but that's quite a substantial thickness of metal, just the body mounts are starting to look like weetabix.
