Body lift
28 Dec 2020 19:21 #231284 by Lambert
Replied by Lambert on topic Body lift
I have had my version for about 25 years, got me out of countless problems.
29 Dec 2020 11:08 #231297 by Roger Fairclough
Replied by Roger Fairclough on topic Body lift
As a matter of interest, how do you remove the bolts?
Roger
29 Dec 2020 12:37 #231300 by Lambert
With either a hole saw or an angle grinder and a welder. Oh and much care.
29 Dec 2020 17:24 #231312 by Roger Fairclough
Another tool to try would be a nut splitter. Clean off all the corrosion. If necessary cut a slot in the large washer that supports the mounting rubber. This will allow you to get the splitter full onto the nut. There is usually no need to go full depth on the nut, just enough to spread it a little. Mole grips or a small pipe wrench will then remove the nut. You may be lucky and find the thread covered by the nut to be in good enough condition to re-use but once the body is off I would use an angle grinder to form a taper on the corroded threads. This will make re-assembly easier.
Roger
18 Feb 2021 21:16 #232972 by Mike G
Replied by Mike G on topic Body lift
Well, today I managed to get my chassis nuts off. All 6 remaining nuts were heated and hydro-shocked. They span off the threads quite easily after that. Looks like I will be able to use the same threads to reassemble the body again, which saves me a load of hassle. Hope to get the body split tomorrow and get some of the body repairs done at the weekend. Fingers crossed that the chassis is in good nick after the rust is needle-gunned off.
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
  • X8GGY
19 Feb 2021 08:29 #232983 by X8GGY
Replied by X8GGY on topic Body lift
Good News Mike! B)
Time to create page: 0.225 seconds
