Body lift
27 Dec 2020 17:43 #231242
Buy a few of these, or similar, for your grinder...
www.toolstation.com/abracs-wire-twist-knot-cup-brush/p17385
then see whats left... and start with fresh metal from there
P.S. DONT FORGET THE PPE USING THIS SORT OF THING :laugh:
27 Dec 2020 17:53 - 27 Dec 2020 18:58 #231243
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
I'm going all out on it I think. I've got plenty wire wheels and flapper discs.
Once the body is split from the chassis, I might send it to the local shotblasters, or maybe do it myself. Will just have to see what the costs are and weigh up either hiring kit or just getting someone to do it.
Last edit: 27 Dec 2020 18:58 by Lambert. Reason: Swearing. Please remember this is a family friendly forum.
27 Dec 2020 21:29 #231252
by Mike G
Thanks for all the responses guys. Very helpful suggestions.
I'll hopefully get the body split in the next week or so and then I'll get all the welding done over the coming month. I think a few of those captive bolts will need to be replaced and I'm guessing I'll have to cut in from the floor of the body to get access to them. Apart from that, it's mainly grinding and painting that will take the bulk of the time.
- Roger Fairclough
- Thank you received: 225
28 Dec 2020 11:30 #231260
by Roger Fairclough
Replied by Roger Fairclough on topic Body lift
I would replace all bolts as a matter of course. I suggest you use a 1-1.6 mm cutting disc and slice off the end of the bolt. Then turn the cutting disc through 90degrees and slice upwards to cut the nut in half. Yes you can try all the other ideas first and suffer the aggro involved but why bother. Two cuts per bolt and job done.
Roger
Roger
28 Dec 2020 11:45 #231261
by Mike G
You're probably right given that most of those bolts do look beyond use.
Do you know if the captive bolt heads are easy to access, it looks to me like every one will need the floor cut open at access and replace.
- Roger Fairclough
28 Dec 2020 17:02 #231266
by Roger Fairclough
Sorry Mike, I can give you technical advice on a generic basis but not specific issues relating to Gen.3 motors as I never worked on them.
Roger
Roger
Time to create page: 0.251 seconds
