'05 Corrosion advice Most appreciated....
- TillymintDLG
01 May 2020 19:52 #221754
by TillymintDLG
Replied by TillymintDLG on topic '05 Corrosion advice Most appreciated....
Must admit making a hole for a drain is a must! What do you suggest 10mm Ø?
Gaz
Gaz
01 May 2020 20:11 #221756
Replied by jackonlyjack on topic '05 Corrosion advice Most appreciated....
On mine the hole was sort of there already
If you feel with your finger there is a recess on the bottom
I just pushed it with a screw driver
And a hole appeared it's around 10mm
The following user(s) said Thank You: TillymintDLG
- TillymintDLG
01 May 2020 20:38 #221757
by TillymintDLG
Can you still buy the rubber seats Jack? I can only find suspension bushes?
Gaz
Gaz
01 May 2020 20:50 #221758
Drop Martin Lines a message he should be able to get some
Or get some good used ones
- TillymintDLG
01 May 2020 22:39 #221766
by TillymintDLG
Cheers for that Jack !
Gaz
Gaz
02 May 2020 07:56 #221776
Replied by mlines on topic '05 Corrosion advice Most appreciated....
Rear coil spring seat is £22.62 + £5 p&p, stock is in Germany so would take a few extra days, would forcecast w/c 11th May if you wanted one
Time to create page: 0.433 seconds
