Shock extenders question
- TomDK
- wilku
Martin - why wont the spacers fit? Both in front and in the rear they will relocate the mounting point and rotate the shock mount by 90 degrees. From what I've seen and measured there's plenty of space on the front to fit an extender like that... Am I missing something???
//EDIT: found a bits4vits blog entry about rear spacers used on the front: www.bits4vits.co.uk/store/re-lifting-the-jimny/blog_246.html
I'll do it the same way.
1066Boy - what do you mean by ARB? And how on Earth are exntendrs + spacers giving extra flex? The travel distance of the shock and spring won't change. The only gain is the clearance.
- 1066Boy
ARB = Front Anti Roll Bar.
By extending the shock mounting point you are effectively extending the total length of it when fully extended so allowing more
travel when that wheel is not under load. You get the same effect on the front when the Arb is removed as it restricts travel.
An extender designed for the front has different dimensions because it has to fit in the space between the existing mounting bracket and has to have the height to clear the mounting bracket. Therefore it is narrower that the published dimensions for the rear.
However the converse is normally true, a front bracket will fit the rear
Knowing Dave at Bits4vits, I am sure his brackets are designed properly to fit.
An extender will only permit more flex if the shocks were hitting their internal stops before the extender was added.
You are not changing the distance the wheel can travel as the shock still has the same stroke. All you are doing is moving the body higher relative to the axles. The suspension will not articulate any more than standard.
A lot of people go this cheap route. If they flexed their standard Jimny with the arb off before the lift and then after they would see.
Proper springs and shocks are the way
Grey pick up Jimny
