Shock extenders question
  • wilku
31 Jan 2017 09:03 #177548 by wilku
Replied by wilku on topic Shock extenders question
I also agree with Busta. It's just relocation of the springs and shocks. And my goal now is only more clearance, as I often tend to go greenlaning and I use routes and paths used by farm equipment mainly, so my main obstacle are their tracks (grooves / ruts) and I need more clearance.
The next step will be of course getting a proper spring + shock lift and by then I will have these extenders tested and will be able to re-sell them.
Martin - I 'designed' (i.e. figured out the dimensions) the extenders myself, based on measurements of my own Jimny, and took the front as reference, so it should be fine. We'll see some time next week.
31 Jan 2017 09:41 #177549 by X8GGY
Replied by X8GGY on topic Shock extenders question
wilku wrote: //EDIT: found a bits4vits blog entry about rear spacers used on the front: www.bits4vits.co.uk/store/re-lifting-the-jimny/blog_246.html
I'll do it the same way.
Glad to be of assistance ;)
mlines wrote: Knowing Dave at Bits4vits, I am sure his brackets are designed properly to fit.
Why thank you Sir ;)
31 Jan 2017 09:42 #177550 by X8GGY
Horses for courses, most of us start with spacers and move to 'proper' lift kits as the hobby (obsession) develops... ;)
  • 1066Boy
31 Jan 2017 16:40 #177560 by 1066Boy
Replied by 1066Boy on topic Shock extenders question
OK so the shock piston still travels the same amount. By adding the extensions I have increased the length between the two
mounting points by 40 mm on full compression. No bad thing as my tyres will hit the arches anyway. :)
On full extension, I have increased the point between axle and chassis by 40mm giving me more travel (tyre from wheel arch)
I have +2" springs and +2" shocks. Add to this 40mm extensions, its 40mm that the axle can move at the point that the
shock attaches before the shock tops out. If this is wrong please explain. :unsure:
Sure maybe I termed it wrong when I said more flex. More axle droop would of been more appropriate. :)
  • TomDK
31 Jan 2017 17:27 #177562 by TomDK
Replied by TomDK on topic Shock extenders question
No. Amount of travel is the same as the 40mm adds to both compressed and extended length.
But yes, more downtravel on the cost of uptravel. With the risk of springs falling out if you're not using spring spacers, spring clamps or longer springs.
  • 1066Boy
31 Jan 2017 17:50 #177566 by 1066Boy
That was what I meant. :) Same travel but increased droop. Yes I have spring locators as they was trying
to escape. :)
Time to create page: 0.519 seconds
