3rd/4th gear noise?
  • Justin83
21 May 2017 11:31 #181378 by Justin83
Replied by Justin83 on topic 3rd/4th gear noise?
It seems I have the same problem!-(
Did you get it sorted?
How long did you drive it for and did it collapse?
What was the cost?
Damd cars...
21 May 2017 12:52 #181380 by gilburton
Replied by gilburton on topic 3rd/4th gear noise?
I avoided it for a little while by shortshifting from 2nd to 5th as the Jimny is quite tractable.
However I would recommend getting it sorted sooner rather than later as you may trash Suzuki only parts in the gearbox and that will cost a lot more.
If the bearings actually go you will probably damage the shafts as well.
I believe Suzuki were quoting(some time ago) £2500 for a recon box.
I had mine done locally for app £650 inc a new clutch kit.
That was also for removing the gearbox so if you can do that yourself you'll save a lot on the labour cost.
I believe Martin in the Jimny shop can supply a similar rebuild kit?
I started off high and worked my way down ever since :-)
  • Justin83
21 May 2017 13:07 #181381 by Justin83
Thanks, the missus uses it for work so I hope it can manage till Friday and then she has half term due to working in a school. I will get it booked in somewhere then...
May be able to have it off myself, read the cross member can be an issue tho.
Anyone got experience removing the 2005+ boxes?
21 May 2017 13:10 - 21 May 2017 13:11 #181382 by gilburton
I believe it can be done by easing the box back and removing the clutch which will allow the box to drop down.
I think Martin ratchetted his engine forward a bit as well?
I think it'll be ok just driving locally just don't thrash it down a motorway lol
Last edit: 21 May 2017 13:11 by gilburton.
The following user(s) said Thank You: Justin83
21 May 2017 16:58 #181389 by mlines
Replied by mlines on topic 3rd/4th gear noise?
Yes - I removed the rad and ratcheted the engine forward on my standard M13.
On my sons VVT we had a gearbox company do the work. They had a fixed labour charge of £300 for a gearbox strip and rebuild (including removal from car). I understand "I got my moneys worth!" based on the removing of the box from the car :)
  • Justin83
23 May 2017 11:52 #181450 by Justin83
That's cheap! I had a quote from a local garage at £1580 Inc vat!!! Since then I had 4 quotes all around the 1000£ mark Inc clutch and 12mnth warranty.
It's at the gearbox centre in sheerness as we speak, box is already out. They just called me saying the clutch looks brand-new but has crumbled around the edges, they suspect it's had a 'cheap' clutch pretty recently. We've only had it for 6months and 6000 miles.
I will report back when it's all done, the got it today and expect it ready for collection Friday!
Time to create page: 1.468 seconds
