3rd/4th gear noise?
  • Riccy
  • Banned
  • Banned
  • J999 MNY Bashing around Carlisle
23 Apr 2016 07:12 #165672 by Riccy
3rd/4th gear noise? was created by Riccy
Having recently spent a small fortune sorting out the kingpins/wheel bearings and adding in a 2" lift and soundproofing, the little jimny has started on a new problem...
when in 3rd or 4th gear it makes a sort of rattly bearing whine under acceleration or engine braking. Its totally silent in 5th and its hard to hear much in 1st or 2nd. If i dip the clutch when its making the noise it stops.
I cant really tell what its doing if i put it in 4x4 high as dont have anywhere to get up to speed off road, and in 4x4 low it always makes a horrible noise anyway.
Its done about 40k miles from new and is an 07 plate. The clutch isnt great and i was wondering if it could be the release bearing making the noise?
Any thought would be appreciated,
Thanks
Ric
23 Apr 2016 07:16 #165673 by facade
Replied by facade on topic 3rd/4th gear noise?
Most likely it is a bearing in the gearbox. The VVTs are well known for it.
You can buy the "rebuild kit" with all the bearings for about £120, or strip it down and just source the noisy one.
You would pay about the same for a second hand gearbox, and that will likely whine too.
23 Apr 2016 08:03 #165676 by gilburton
Replied by gilburton on topic 3rd/4th gear noise?
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationTry nearer £700 for a s/hand R72 box. The breakers are well aware the box is in demand.
However having said this there is one for sale that is extremely cheap but it's for spares/repair with bearing problems!!
I started off high and worked my way down ever since :-)
  • Riccy
  • Banned
  • Banned
23 Apr 2016 15:14 #165685 by Riccy
Replied by Riccy on topic 3rd/4th gear noise?
OK, thanks for the info. will see about blagging a mate to rebuild it, is beyond my abilities i think.
will it just collapse one day and then game over if i keep driving it? dont want to crash or damage other parts if thats a risk?
23 Apr 2016 15:53 #165691 by facade
Riccy wrote: will it just collapse one day
Yes, has happened to several members, including Martin.
Might trash the gears, might not.
Best to get it done rather than worry about it.
23 Apr 2016 15:53 #165693 by gilburton
The following user(s) said Thank You: Roly6555, Riccy
Time to create page: 0.874 seconds
