3rd/4th gear noise?
27 May 2017 05:58 #181561 by gilburton
Replied by gilburton on topic 3rd/4th gear noise?
Well it will probably feel different with the new gears and clutch.
They would have had to disconnect the clutch cable to get the gearbox out but it is possible they haven't adjusted it correctly as most garages these days are used to self adjusting cables.
You can easily check it yourself.
If you go underneath and find out where the cable enters the gearbox. There is an angular plastic cover that you remove by pinching in the sides. You should now see the plastic threaded adjuster.
It should be adjusted untill you have a couple of mm slack on the outer cable a bit like a clutch or brake cable on a bike.
Has the gearbox noise gone?
I started off high and worked my way down ever since :-)
The following user(s) said Thank You: Justin83
  • Justin83
27 May 2017 09:46 #181563 by Justin83
Replied by Justin83 on topic 3rd/4th gear noise?
The missus is just picking it up from the mother in law who said it felt stiff, noise is gone she said.
  • Justin83
27 May 2017 10:19 #181564 by Justin83
Well missus is home and said it feels fine.
Just gotta build the enthusiasm to change the passenger halfshaft oil seal for the third time now... Thirty nuts to undo and get covered in diff oil, lovely smell that stuff!-)
  • Justin83
27 May 2017 10:21 #181565 by Justin83
I think I've been damaging Them while locating the long halfshaft on that side... New plan is to slide it on the shaft then push the seal in once the shaft is located....
  • Daniel30
27 May 2017 12:31 #181567 by Daniel30
Replied by Daniel30 on topic 3rd/4th gear noise?
Good luck ;)
  • Justin83
27 May 2017 15:07 #181569 by Justin83
Well all done, other than fighting a brake pad that popped out all went smoothly. I couldn't push the oil seal in while on the shaft so was double careful.
Ah also left an extension bar wedged in the hub and bolted the disc on, lucky I had a wipe up round the back and saw it!!! Eeek.
I'm not driving it till tomorrow, mainly so I'm not depressed all night!-) hopefully it's third time lucky.
Thanks everyone.
Time to create page: 0.144 seconds
