newbie with a problem
23 Feb 2015 18:37 #138938
Replied by Daniel30 on topic newbie with a problem
Thanks helijohn
23 Feb 2015 18:41 #138941
by kirkynut
Replied by kirkynut on topic newbie with a problem
o answer a couple of questions - yes you can grease the CV when you do the king pin bearings as you need to pull the shaft out with the CV on or at least can do and I found a Halfords Professional 1" socket fits nicely just inside the race to knock it out from the outside as it fits inside the hole on the swivel but not through the race.
The following user(s) said Thank You: Daniel30
- The Dug
24 Feb 2015 14:30 - 24 Feb 2015 20:45 #139008
by The Dug
Replied by The Dug on topic newbie with a problem
Hi Daniel, welcome to the site.
I've used this forum to do quite a few jobs on my Jimny and these guys are top class in both the advice offered and the depth of knowledge available. Use the Big Jimny Store for as much as I can too - top service and prices.
One thing I experienced when changing the KPB's on mine was that I had a few rounded bolts which had to be replaced due to corrosion/rounding (a lot were dealer only replacements too so there was an added waiting time for delivery - not to mention the cost). If I remember correctly the hub bolts and the swivel seal bolts were the worst for me, I also ended up having to cut off the tie rod end so had to replace that. Another small point on that, I don't think it's recommended to re-use the nyloc nuts on the tie-rods either but these are fairly cheap to buy.
Wasn't a big deal for me as I was replacing just about everything on the front hubs anyway but something to consider before diving in with spanners.
There are far more experienced home mechanics (and qualified ones too) on here than me so I'd follow their advice before mine but thought I'd pass on my tuppence worth.
Good luck
Good luck
Last edit: 24 Feb 2015 20:45 by The Dug. Reason: Poor choice of words - sorry
- markyp2000
24 Feb 2015 18:13 #139038
by markyp2000
Replied by markyp2000 on topic newbie with a problem
Hi iv messaged you. im far from a home mechanic lol im qualified (19 years for my sins ) but people on here do know what thay are on about
- The Dug
24 Feb 2015 20:47 #139065
by The Dug
Should have worded that better mate, no offence intended. I was trying not to imply that I was in any way a mechanic didn't mean to suggest nobody was.
- markyp2000
25 Feb 2015 00:25 #139088
by markyp2000
No offence taken hence why it had lol at the end. it takes alot more than the to offend me :laugh: :woohoo:
The Dug wrote: Should have worded that better mate, no offence intended. I was trying not to imply that I was in any way a mechanic didn't mean to suggest nobody was.
Time to create page: 0.157 seconds
