Mounting Goodwinch 9.5c on Ora winch plate
  • ne-crock
23 Apr 2014 14:19 #113070 by ne-crock
Replied by ne-crock on topic Mounting Goodwinch 9.5c on Ora winch plate
what if the electric isolater welds the terminals? for the sake of £10 for a manual switch why not have both?
  • TomDK
23 Apr 2014 14:32 - 23 Apr 2014 14:49 #113071 by TomDK
Replied by TomDK on topic Mounting Goodwinch 9.5c on Ora winch plate
ne-crock wrote: what if the electric isolater welds the terminals? for the sake of £10 for a manual switch why not have both?
And what if and what if and what if??
What if both isolators weld... ? That is a possible risk, if you only use cheap stuff.
Instead, spent money on a good quality isolator, not just a cheap £10 one.
like this one perhaps www.red-winches.com/products/albright-wi...tor-12v-solenoid/62/
Or this:
gigglepin4x4store.gostorego.com/durite-b...lashproof-cover.html
Last edit: 23 Apr 2014 14:49 by TomDK.
  • TomDK
23 Apr 2014 14:33 #113072 by TomDK
Yellostreak wrote:
TomDK wrote:
Also, there's no reason for 2 battery cut off switches. One is sufficient.
So long as its at the Battery end... :)
you only need two isolators if you have a cable going from battery 1 to Battery 2 in a two battery split charge system
Exactly, as close to the battery as possible. And the winch solenoid as close to the winch as possible :)
  • barnes
23 Apr 2014 15:15 #113079 by barnes
Replied by barnes on topic Mounting Goodwinch 9.5c on Ora winch plate
TomDK wrote:
barnes wrote: I replaced my winchmax with the 9.5 goldfish cracking winch! Was a tight squeeze though and with the solenoid box fitted I had to trim the bonnet and cut the crossmember but its all about the performance!
Yes I could have but the solenoid is neatly installed with buzz bars why would I want too plus the cost of cable thick enough to prevent resistance id rather just chop a cross member
  • TomDK
23 Apr 2014 15:20 #113080 by TomDK
Have you cut the entire crossmember off?
It is a essential part of the structural integrity of the body. So if that has been cut off completely, you need to make something as a substitute.
50 mm2 cables aren't that expensive :)
  • barnes
23 Apr 2014 15:44 #113083 by barnes
Its been trimmed thats all so wont fall apart anytime soon! Plus the strongest part of the jimny is the winch plate thats been installed! Nope its not but why mess with something you dont need to
Time to create page: 0.173 seconds
