Mounting Goodwinch 9.5c on Ora winch plate
  • Yellostreak
23 Apr 2014 17:17 #113090 by Yellostreak
Replied by Yellostreak on topic Mounting Goodwinch 9.5c on Ora winch plate
TomDK wrote:
Yellostreak wrote:
TomDK wrote:
Also, there's no reason for 2 battery cut off switches. One is sufficient.
So long as its at the Battery end... :)
you only need two isolators if you have a cable going from battery 1 to Battery 2 in a two battery split charge system
Exactly, as close to the battery as possible. And the winch solenoid as close to the winch as possible :)
yep.. don't want that 50mm2 cable acting like a fuse!
fully agree about using top quality gear too but I think this red and gigglepin stuff is overpriced 'because it can be' buying proper specification stuff rather than cheap sh1t from China/ebay will prevent something nasty happening!
  • TomDK
23 Apr 2014 17:24 #113093 by TomDK
Replied by TomDK on topic Mounting Goodwinch 9.5c on Ora winch plate
Overpriced. maybe :)
I just haven't found any isolators/solenoids with same specs that are much cheaper. I use a 2500 AMP/10 sec battery isolator solenoid for my winch. This isn't any cheaper :)
  • jimnydms
23 Apr 2014 22:19 #113149 by jimnydms
Replied by jimnydms on topic Re:Mounting Goodwinch 9.5c on Ora winch plate
I have a 9.5 installed with a O R A bumper very tight squeeze but no crossmember trimming. Solonoid mounted under bonnet and electric solonoid isolator all powered by odyssey pc1200 ! Yet to try in aggression yet lol
  • mike390
24 Apr 2014 09:46 #113174 by mike390
Replied by mike390 on topic Re:Mounting Goodwinch 9.5c on Ora winch plate
jimnydms wrote: I have a 9.5 installed with a O R A bumper very tight squeeze but no crossmember trimming. Solonoid mounted under bonnet and electric solonoid isolator all powered by odyssey pc1200 ! Yet to try in aggression yet lol
Looks like a really good set-up.
Does the odyssey battery fit right in, or did you need to alter anything?.
  • jimnydms
24 Apr 2014 21:58 #113231 by jimnydms
ORA made me a custom mount for that battery very cheap and good quality just need a coat of laquer and paint. Took the plastic tray out and grinded off the lips of the original tray and bolted the new one to the original one. Then re mounted the fuse box to the side of the new battery cradle. Looks smart lots of making new bits of cable up bit well worth it
That pic hasn't got the lid across the cradle on
  • mike390
25 Apr 2014 09:37 #113283 by mike390
Thats good to know, have heard that this is probably the best battery to get, also good ifcan keep in same place as original battery :)
Time to create page: 0.156 seconds
