Mounting Goodwinch 9.5c on Ora winch plate
  • mike390
23 Apr 2014 11:57 #113055 by mike390
I am thinking of buying a goodwinch 9.5c and mounting it onto an ora winch plate
A couple of concerns I have are
1.My jim has air conditioning, if I remove the fan will the winch fit ok?
2.Would it be ok to run the winch off of standard battery to start with and upgrade to an optima yellow top in the future, I only intend to use the winch for self recovery when greenlaning etc.
3.Do I need some sort of battery/winch cut off switch
Any sugestions welcome :unsure:
  • ne-crock
23 Apr 2014 12:11 #113056 by ne-crock
Replied by ne-crock on topic Mounting Goodwinch 9.5c on Ora winch plate
1: I'm not sure my jimny doesn't have air con but I believe it's an issue when fitting a winch?
2: I currently run the same winch off my standard battery, it's been okay but I wouldn't want to long spells with the winch only quick recoveries
3: it's advisable to, be it a manual isolated switch or an electric operated one, or better fit both
  • mike390
23 Apr 2014 12:21 #113057 by mike390
Replied by mike390 on topic Mounting Goodwinch 9.5c on Ora winch plate
ne-crock wrote: 1: I'm not sure my jimny doesn't have air con but I believe it's an issue when fitting a winch?
Thanks, good to know battery would be ok to start with, need all my pennies to pay for winch
Will look into getting isolation switch
  • barnes
23 Apr 2014 12:59 #113060 by barnes
Replied by barnes on topic Mounting Goodwinch 9.5c on Ora winch plate
I replaced my winchmax with the 9.5 goldfish cracking winch! Was a tight squeeze though and with the solenoid box fitted I had to trim the bonnet and cut the crossmember but its all about the performance!
  • TomDK
23 Apr 2014 13:48 - 23 Apr 2014 13:50 #113065 by TomDK
Replied by TomDK on topic Mounting Goodwinch 9.5c on Ora winch plate
barnes wrote: I replaced my winchmax with the 9.5 goldfish cracking winch! Was a tight squeeze though and with the solenoid box fitted I had to trim the bonnet and cut the crossmember but its all about the performance!
You could have easily moved the solenoid up under the bonnet, so you wouldn't have to cut the crossmember.
Also, there's no reason for 2 battery cut off switches. One is sufficient.
Last edit: 23 Apr 2014 13:50 by TomDK.
  • Yellostreak
23 Apr 2014 14:07 #113068 by Yellostreak
Replied by Yellostreak on topic Mounting Goodwinch 9.5c on Ora winch plate
So long as its at the Battery end... :)
you only need two isolators if you have a cable going from battery 1 to Battery 2 in a two battery split charge system
Time to create page: 0.329 seconds
