Swivel Filled With Grease - Removing Excess
23 Dec 2013 14:37 #97265 by facade
The whole lot comes off in one with the halfshaft attached, just disconnect the vacuum pipes, split the steering joints, remove the calliper undo the bolts around the large dust seal and pull it inwards, then whip the kingpins out.
You may find that the reason it leaks is because oil is coming out of the axle seal though...
  • markyp2000
23 Dec 2013 15:42 #97281 by markyp2000
Replied by markyp2000 on topic Swivel Filled With Grease - Removing Excess
Even if i was taking it apart dew to the one shot stuff id replace the oil seal just so i no its good
  • Yellostreak
23 Dec 2013 16:28 #97287 by Yellostreak
Replied by Yellostreak on topic Swivel Filled With Grease - Removing Excess
markyp2000 wrote: Even if i was taking it apart dew to the one shot stuff id replace the oil seal just so i no its good
AGREE.. its a doddle job to replace it while you have it apart.. plus I'd be suspicious at what is pushing the grease out, might be a leaking seal anyway!
  • GuardianAngel
23 Dec 2013 16:39 #97288 by GuardianAngel
Replied by GuardianAngel on topic Swivel Filled With Grease - Removing Excess
Agree as well. I gutted everything when I just needed a bottom bearing and replaced both the seals and both bearings.
  • hunter1084
23 Dec 2013 23:55 #97362 by hunter1084
Replied by hunter1084 on topic Swivel Filled With Grease - Removing Excess
+1 Keep the old seal aswell in case you ever need it again
  • ORM13
24 Dec 2013 03:43 - 24 Dec 2013 07:07 #97375 by ORM13
Oil seals ordered, so the job is postponed for a few days.
Thanks for all the info guys.
Will see how it goes!
One last question, it looks as though the diff oil was changed recently. If I do one side of the Jimny at a time, will I lose much when removing the oil seal?
Last edit: 24 Dec 2013 07:07 by ORM13.
Time to create page: 2.229 seconds
