Swivel Filled With Grease - Removing Excess
24 Dec 2013 08:11 #97383
by facade
Replied by facade on topic Swivel Filled With Grease - Removing Excess
Jack that side up only, and very little, if anything will come out.
The following user(s) said Thank You: ORM13
25 Dec 2013 06:12 #97483
First thing that I thought when I read the post so it'll be interesting to see what the situation is. Also, I know the grease needs room to expand etc. but won't there come a time when sufficient has been forced out so it can be left???
Replied by helijohn on topic Swivel Filled With Grease - Removing Excess
Yellostreak wrote: I'd be suspicious at what is pushing the grease out, might be a leaking seal anyway!
- ORM13
25 Dec 2013 06:18 #97484
by ORM13
Replied by ORM13 on topic Swivel Filled With Grease - Removing Excess
Apparently the hub has been completely filled to the brim with one shot grease. As the Jimny is used, it's coming out through the swivel seal.
It's not pouring out, but after a a few days driving there's enough to build up a blob on the back of the swivel that then drops off on the wheel/tyre/driveway.
Before it was filled up, nothing came out at all.
I'm sure after time it will stop as it's got through the excess, but I'd rather clean it up and put proper CV grease in there.
25 Dec 2013 10:14 #97493
by facade
To be fair, the one shot grease is fine for CVs and bearings, that is what landrover made it for.
Just scoop out some of the excess.
Be warned that it isn't waterproof, and when water gets into the swivel housing it will just sit at the bottom and wreck the lower bearing.
- ORM13
03 Jan 2014 14:37 #98880
by ORM13
Turns out the only reason for the leakage on the ball was due to the large amount of grease in the swivel. So no issues with the seals (although they were replaced).
The CV grease I purchased is the same grey stuff as the one shot stuff.
Is it better to use a thicker normal LM style grease for these?
- GuardianAngel
03 Jan 2014 15:51 #98886
by GuardianAngel
Replied by GuardianAngel on topic Swivel Filled With Grease - Removing Excess
Try the waterproof grease Martin sells in the Big Jimny shop. I used this when I did mine.
Time to create page: 1.171 seconds
