Swivel Filled With Grease - Removing Excess
  • ORM13
23 Dec 2013 06:03 - 23 Dec 2013 06:05 #97232 by ORM13
Hi all, I'm wondering if you can help us.
We've just got a new (to us) Jimny and noticed that there is a lot of grease around the swivel joint.
It turns out the previous owner thought it was a Landy and filled the housing with one shot grease.
The downside of this is that it is now trying to escape.
I've been reading on here that the swivel should be dry apart from the grease on the CV and another small amount of grease. The Kingpin bearings seem good and there's no movement or noise.
To get to the point, if I strip the swivel to clean it out (remove the excess) and grease it correctly, will I have to replace the axle / half shaft oil seal? We can't get a replacement seal before Christmas and was hoping to get this done tomorrow. There's no sign of any axle/diff oil leaking so don't think there's a problem with the old seal, kingpins or bearings.
Or is there an easier way to just remove the excess temporarily? (Don't fancy climbing underneath it every other day to remove the grease).
Thanks if you can give us some help.
Last edit: 23 Dec 2013 06:05 by ORM13.
23 Dec 2013 07:52 #97234 by j999pre
A long as your careful i see no prob in what you want to do,
Where are you? As i have a spare seal
Grey pick up Jimny
  • steffan
23 Dec 2013 07:59 #97235 by steffan
Replied by steffan on topic Swivel Filled With Grease - Removing Excess
+1 should be ok I would De-grease the lot and re-grease it up properly undue the swivel seal it's self remove caliper and kingpins and the hole lot will come off as 1 unit
  • Yellostreak
23 Dec 2013 09:53 #97240 by Yellostreak
Replied by Yellostreak on topic Swivel Filled With Grease - Removing Excess
j999pre wrote: Where are you? As i have a spare seal
Same here.. I have a spare one also
  • Yellostreak
23 Dec 2013 09:54 #97241 by Yellostreak
steffan wrote: +1 should be ok I would De-grease the lot and re-grease it up properly undue the swivel seal it's self remove caliper and kingpins and the hole lot will come off as 1 unit
and the steering link(s)
  • ORM13
23 Dec 2013 14:23 #97262 by ORM13
Thanks guys for all the helpful info.
I'm in Norfolk.
Can I remove the swivel with the vacuum hub still attached or does that also have to come off (I've checked the guide here)?
I feel happier now knowing I won't necessarily have to replace the axle seal.
Time to create page: 0.341 seconds
