Grinding Noise When Pulling Away From Stop.
26 Jan 2014 08:41 #102094 by robs5230
idiotmobil wrote: im going to check mine tomorrow I mite have it along with a few more noises
:laugh: yeah mine seems to talk to me all the time
standard jimny - for now
  • mark141
26 Jan 2014 19:29 #102171 by mark141
Replied by mark141 on topic Grinding Noise When Pulling Away From Stop.
hi does anyone know what the order code for one of these would be and can they be ordered from the uk directly ???
"its the rear gearbox mount. makes the gearbox-transfer propshaft rub on the gear selector mounting when its turning but only under load. about 37 quid from suzuki last time i checked. i had same problem last year."
thanks
mark
  • Leathery1
26 Jan 2014 20:12 #102173 by Leathery1
Replied by Leathery1 on topic Grinding Noise When Pulling Away From Stop.
OK, worried now.
Fried the clutch a little a couple of weeks ago backing out of a lane I thought was too muddy - (now I know better, would have walked it!!!!) Since then I have a short squeal when setting off from stand still, never happens any other time. Could this be t box mount gone?
Also have a squeal when wet (usually deep puddles / fords , not so much when raining) This has happened since a full service by the main stealer a few of years ago ( I'll never make that mistake again!). Thought it was a loose belt but belts seem fine and it stops when I dip the clutch. Could this be knackered clutch plates? Its only done 43K miles!
26 Jan 2014 22:19 #102190 by robs5230
Leathery1 wrote: OK, worried now.
sounds like clutch release (thrust) bearing if it stops when clutch dipped
  • Clo1378
31 May 2019 14:55 #209314 by Clo1378
Replied by Clo1378 on topic Grinding Noise When Pulling Away From Stop.
Can I ask what this ended up being and what you did to fix it?
31 May 2019 15:11 #209315 by mlines
Time to create page: 2.870 seconds
